Parking in the uphill
Many years ago, I parked my XJ6 downhill, probably a 20% slope, for a 15 minute meeting. After which I came to start the motor and the timing chain slipped off -- so I've always been wary since then, even though I'm confident the engineers have solved such matters. FWIW, one thing that I do since the advent of Jaguar electronic parking brakes, when parking on a hill is to apply the parking brake manually before engaging Park. In that way, I avoid the driveaway Clunk normally heard / felt when I'd allow the Park engagement to also set the brake.
This is different from the system in the saloons/sedans in which both the setting and release of the parking brake are automatic.
Finally, the parking brake should always be applied BEFORE pushing the P switch to prevent the car moving against the parking pawl in the transmission when the car is on any degree of incline.
Carbuff2 (04-04-2020)
Received 3,226 Likes
Putting the automatic in P by pushing the switch on the shifter does NOT apply the parking brake. The brake must be applied manually by pulling the switch lever on the console - but it does release automatically. And yes, if your foot remains on the brake pedal as you pull the parking brake lever, you can feel a difference. Once the brake is applied you should also see the BRAKE light (which has different appearance in different markets) in the gauge dispay screen.
I believe this is true only for MY 2013, 2014 and 2015 autos then from MY 2016 the EPB comes on automatically once you turn the ignition off and put the car in P (or just let it go to P by itself like I do).
I for one would find it very annoying if the car automatically applied the EPB and I much prefer my manual operation set up.
Blue Jag 2017 (04-07-2020)
