Parts List for Y-Pipe Repalcement?
I've done some searching and can't locate one. Is there a comprehensive list of what parts and gaskets to replace when doing the y-pipes?
This kit looks pretty comprehensive from Euro Amp. Should I add anything else:
Y-Pipe Kit
Y-Pipe Kit
- Aluminum Heater Pipe (Heater Manifold, Rear Crossover Pipe)
- Aluminum Front Crossover Pipe V2 (Y-Pipe, Front Pipe)
- Aluminum Thermostat
- Mechanical Water Pump
- Thermostat Outlet Hose (Upper Thermostat Hose, T- Hose)
- Brass and or Plastic Water Pump Inlet (Brass Elbow, Brass Nipple)
- Brass Hose Bleeder Screw
- Crossover Return Plug
- Aluminum Oil Cooler Inlet Tube (Water Pump Tube)
- Solid ZZP Supercharger Snout Coupler
- Intake Plenum Gaskets (Supercharger Gasket, Intake Manifold Gasket)
