Don't see much about them here but I pulled the trigger last month and just got around to installing them today. Easy job, plug n play....went from base 355 to an 8 pot 365 mm rotor. Best part is the weight savings. Didn't realize just how massive the oe rotors and calipers are! OE caliper weight is 20.5 lbs. PB caliper is 10 lbs. OE rotors weigh 21 lbs. PB rotors weigh 14. So I gained braking performance and lost 17 lbs per corner of unsprung weight! Can't wait to see how they handle the mountains!
Thanks all. Cost was around $2100 for the front set. Rotors, pads, calipers and braided lines. The rears are actually more because of the built in parking brake so I didn't bother with them.
