Performance Clutch/Flywheel Anyone?
Modern cars should be able to withstand this. This is also why engine mounts provide both compression and decompression resistance. If drive train cannot survive high RPM transition from WOT to closed throttle, then it is not adequately hardened.
I agree with you, but Jag appears to be using the computer to compensate for an under engineered driveline.
I didn't take this feature as making up for an inadequate driveline, it's more of a comfort feature. If someone isn't used to driving a manual, keeping it at the correct RPM for the next gear for half a second makes the shift up go more smoothly.
Ok now I AM confused! What do you call what it has then? When I put in the clutch, it'll automatically hold for a half second at the RPM of the next gear. Is that not rev-matching?
Jaguar claims that the automatic does. At least, in this document, under 'Dynamic Launch', they imply that all that dynamic launch does is not do rev matching, for more violent shifts. If you believe it.
https://www.dropbox.com/s/wskjex70o2...ntrol.pdf?dl=0
2016
No, it very specifically and intentionally hangs at a very specific RPM for a portion of a second. I'll take a video next time I'm in the car since neither of you seem to believe me!
#30
If this were done for the purpose of rev matching on the up shift, they would have allowed the rpm to drop a few hundred rpm before causing it to hang.
#31
I agree, and since that's not what it does, I don't think that's why it's doing it. It's repeatable and consistent enough that I've adapted to not have it happen. I'll have to deliberately try to induce it now to see if the VAP tune has eliminated it.
#32
#33
#34
That's exactly what it does! If I wait, it drops the rpm to where it needs to be for the next gear, holds it there for a bit, and if I don't shift in time, then it drops it all the way to idle.
#36
#37
BTW, the clutch/flywheel builder will have the parts to measure by next Wednesday. The OEM clutch is 18 lbs and the flywheel is 38 lbs.
#38
No need to eliminate the effect. I played with it today. It does indeed hang for a second at an engine speed based on the road speed and next higher gear. The reason I never noticed it is that I typically complete an upshift in half the time it takes for the engine to slow down to that hang point. However, there may be some real value to having that hang point when the lightened flywheel is installed. One of the challenges of driving a lightened flywheel would already be addressed.
Back on topic - this is an exciting project! I will definitely be interested in a lightened clutch/flywheel when the time comes for replacement.
#39
Good to know I am not crazy. I only ever noticed when driving around town and making gentle shifts or running out first and second, letting up and then skip shifting right into fourth. You definitely wouldn't notice if you are on the car all the time.
#40
