Phone holder for F-Type
And where do you attach that? The center vents on the F-Type go up and down (completely disappear) depending upon whether the HVAC system is on or off and whether the car is running or not. There are no other vents to attach it to.
I've searched to no avail. You can go suction cup mount but it looks messy. I would love it if someone made something that attaches the passenger hold bar. These guy make one but it's on the wrong side: http://www.proclipusa.com/dashboard-...912-19416.cmsv
blgN8 (10-16-2022)
the eternal pro/con of picking a relatively rare car...custom car seat covers, custom phone holders, aftermarket wheels, etc. aren't as readily available....
I use the clip about the size of a thimble and is a powerful magnet. Unfortunately the F-type doesn't have the best vent layout as my old car. A simple metal card did the trick. I'll probably shave it down to just what I need and then the holder disappears into the car. It is a twist clamp. On your phone you have a flat round piece of metal half the size of a dime.
Pardon the dusty car.
I've used the Tetrax before, and have loved it.
They make several versions, two of which are adhesive backed and do not require a vent.
The "Smart" - Smart - Tetrax - Magnetic Passion
The "Fix" - Fix - Tetrax - Magnetic Passion
The vent can be programmed to stay up all the time, but that's not a very elegant solution either.
I'm using the ProClip solution for the F-type. I wasn't sure I'd like it, but now that it's installed, I find it to be the best compromise in an already busy driver control area. Positionally it's just a little lower than what's shown in the picture Lynx posted above. It does somewhat block the start button, but you only use that twice per ride, and only when parked, so not a real issue. In use, it's ideally placed for easy access with your right hand (for those of us with left drive cars) making it easy to post Waze reports. It's also very well made. I'll try to get some pictures tomorrow.
Proclip makes an F-Type phone bracket. Has anyone tried this?
Jaguar F-Type 2013-2016 ProClip Console Mount - ProClip USA
I have used this spiderpodium for over a year, no problem at all.
f_in_seattle (05-23-2015)
