Phone holder for F-Type
Old 11-04-2017, 11:00 AM
911Königin's Avatar
Originally Posted by shift
Nice set up! But, I don't want to have to give up my "OH ****" handle.
  #102
Old 11-06-2017, 11:28 AM
Uncle Fishbits's Avatar
Originally Posted by Foosh
That simply does not work for me as a tall person.
Ditto. But regardless, the best of all options seems to be anchored on the left side of the in control. I hate taking my eyes off the road if unnecessary. It does get the left vent, while blowing, but it's really ideal, only rests over the top left in-control button, which I apparently don't use very much because I can't remember what I am blocking. Maybe "home"?
  #103
Old 11-06-2017, 05:52 PM
woodturner's Avatar
Installed mine this afternoon. Placed it where malbec has his - in front of the pop-up vents - but I placed mine directly in the center. I think I'll like this solution very much. Sure is nice having the phone available at the proper height, ready for a quick glance.
  #104
Old 11-09-2017, 03:15 PM
Sonoman's Avatar
The Scosche MAGDMB and Caseco 360 are good solutions, this Anker mount is another. It's essentially a steel ball with a small attached plate for the phone. The ball rotates freely in a cup mounted to the dash with 3M tape.
Amazon Amazon
I mounted it above the Nav screen so that Waze stays close to my field of view. It does block my dash vent but that's seldom a problem. We just returned from 1400 miles around California and it held my Pixel XL in position very well, nary a slip despite some... assertive acceleration and cornering.
  #105
Old 11-09-2017, 03:39 PM
woodturner's Avatar
This is where I placed mine. I'm very happy with the location as it keeps the phone accessible with my right (dominant) hand and holds the phone at the right height allowing for a quick glance.
  #106
Old 11-24-2017, 04:25 PM
woodturner's Avatar
Assuming that folks are using the power outlet under the arm rest in the center console, how are you running the power cable out of the console? The cleanest way that I can see would require drilling a hole in the console, but I hate making modifications which are not totally reversible. (I'm funny like that I suppose.) Anyone have a clever way of dealing with this?
  #107
Old 11-24-2017, 06:26 PM
OzXFR's Avatar
Received 3,217 Likes on 2,372 Posts
I also have a Scosche mount and I use the power outlet on top of the console next to the gear lever. But I don't use it all that often let alone permanently as my phone holds a charge for quite a while (Samsung A7).
  #108
Old 11-25-2017, 12:18 AM
malbec's Avatar
I have a 2m black cable which runs forward from under the centre armrest down beside the seat along the floor and up to the Scosche mount. You hardly notice the cable.
  #109
Old 11-25-2017, 04:15 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
You can run the cable out the back of the center console (there is a gap near the hinge)and tuck it up under the tranny tunnel (center console) trim on the passenger side, as mentioned, where it meets the carpet. Then run it forward to where the trim ends behind the glove box door.
malbec (11-25-2017)
  #110
Old 11-25-2017, 09:17 AM
woodturner's Avatar
That's exactly the path that I took but I don't have it running to the side of the console's hinge as you have done. I tried running it between the two hinges, centered, but felt as if subsequent closing of the console lid would likely, over time, pinch the cable resulting in a stress point. I'll have to try running it lateral to one of the hinges and see how that goes.
  #111
Old 11-25-2017, 10:27 AM
Unhingd's Avatar
Run it to the outside of the passenger side hinge. There's a sizeable gap right there.
  #112
Old 11-29-2017, 05:53 PM
Ichi Ban's Avatar
I stick my phone in the cubbie behind and between the seats. Not the best but, with bluetooth, it works.
  #113
Old 10-29-2021, 09:52 AM
harryf's Avatar
I bought the Soche magnetic and adhesive mount. It was not strong enough to use with my thin ESR Mimic case, unless you put the metal plate on the outside of the case, so I returned it. I got the Humixx https://humixx.net/collections/accessories-proctection/products/magnetic-car-phone-mount-1. It works really well. I've also used the KAVVO one in my XF though it is smaller but almost as strong, to fit in the ashtray area on the popup cover.
Amazon Amazon
  #114
Old 11-11-2021, 12:29 AM
kevin_jag's Avatar
  #115
Old 11-11-2021, 02:05 AM
JacksonvilleJag's Avatar
I use this one and I really like it. Just wish it was wireless charging. If anyone comes across one like this with wireless charging, please let me know.
Amazon Amazon
  #116
Old 11-11-2021, 03:52 AM
Robtrt8's Avatar
blgN8 (10-17-2022)
  #117
Old 11-11-2021, 12:40 PM
Fireze22's Avatar
Originally Posted by kevin_jag
And when the visor is open?
  #118
Old 11-11-2021, 04:03 PM
kevin_jag's Avatar
I was imagining connecting it to the passenger grab handle, it doesn't look like it articulates much tho so it might not work very well.
  #119
Old 11-11-2021, 05:47 PM
Fireze22's Avatar
That's exactly where I'd want to place mine. Seems an ideal place.
  #120
Old 11-12-2021, 06:06 PM
harryf's Avatar
I would think it blocks too much of your view.
Quick Reply: Phone holder for F-Type
