pic of motor shows up
CEL
The CEL, Check Engine Light may illuminate if your gas cap isn't snug and you may want to check your coolant container cap for the required 3 clicks to make sure it's on correctly. I don't remember if the coolant cap issue will turn on the CEL, but do check this anyway.
Also, if you had a drastic temperature change,, like warm to cold, this may make the CEL come on. It did that on the MY2017 that I have. Be careful using the OBD readers. Some of them create battery drain issues if the session is not closed out properly... there are whole threads devoted to this.
