Plastic Coolant Lines
I am new owner this year of a 16 F-Type R V-8. I do all my own maintenance work, on all my vehicles. I keep reading on the Forum about the plastic coolant lines that are brittle and crack and leak. So with my car being almost 5 years old, I am thinking I should probably replace these lines before a problem occurs even though it only has 17,000 miles on it. So does any one have a list of all these plastic lines with part numbers and descriptions that should be replaced?? I figure a good winter project would be to replace the lines, hoses, and coolant while I'm at it.
The part numbers that have been posted in the past (not sure which engine they apply to, if not both the V6 and V8):
Connector tube AJ811997
Outlet pipe AJ813865
Outlet pipe o-ring (2) AJ811350
Engine coolant pipe AJ813917
Radiator coolant hose T2R7744
Engine coolant pipe C2Z28258
Heater outlet pipe, crossover pipe AJ814007
Thermostat kit C2Z19929
Received 3,259 Likes
Part # T2R5910, get it from Britcar for cheap see here: https://www.brit-car.co.uk/search.ph...t=&xPerPage=10
scm (11-29-2020)
arctic_man
07-31-2020 05:59 PM
Canaan David Khoury
03-20-2020 12:22 PM
dolamyte
04-21-2015 07:16 AM
