Please help me understand the difference between the 340 and 380 hp V6 models
Aside from the obvious power differences, and the fact that the 380 hp has the limited slip differential, what other performance differences are there between these two models? Does the 380 hp version have a better suspension or larger brakes?
Thanks.
Thanks.
I went through the same thought processes you seem to be going through and arrived at the conclusion: I did not need the 380HP version--also after test driving both on multiple occasions. I can tell you that since accumulating the break-in miles I have not been able to break the rear tires loose under any circumstances, so I don't know what the need for a limited slip diff. would be.
Uncle Fishbits (09-27-2018)
May depend on the year. V6S has adjustable dampers, which I think helps on bad pavement. Also has active exhaust, which may be an option for the base. 19” wheels and bigger front brakes, which are also options. More power, though you can get a reasonably priced tune to bump the base up to 400ish HP, should that be of interest. In MY14, the base didn’t have Dynamic mode, but it does in later years (not sure when that started.)
I would actually be fine with the 340 hp model. I am just trying to understand the other differences and the Jaguar website is not clear on this.
My 2 cents - If you are into performance, the S model is worth the money - bigger wheels, brakes, active exhaust, limited slip, better suspension. And while you can tune either trim to 400hp, getting the S with a full warranty on the 380 HP is a plus. If you just enjoy the looks of the car and typically don't push the limits of cornering or acceleration, get the base.
One additional thought. Depreciation on performance/luxury cars is brutal the first couple years - why not consider a used R or S instead of a new base. In 2 years you might be glad you did....
Yes, the MT is tough to find used, not enough owners selected them originally - I hear the number of folks that don't even know how to drive a manual anymore is huge and growing.
Lease makes sense in your situation, plus you get the advantage of not sweating every little scratch or scuff that appears on the car. If the lease payment differential isn't huge, I'd suggest the S....
Also, most of the initial problems pop up during the first year.
So true. And it will only get worse - just wait until driverless cars get on the road - computer-driven cars would never have an electronic failure (a life-endangering one) , would they? Definitely not, nope, not possible. I'm pretty sure about that.Uh....hmmmm...well....
The following 2 users liked this post by sov211:
Mbourne (09-22-2018),
scm (09-23-2018)
I have to be careful with my V6s because its all to easy to spin the wheels out and you can get the back end out of shape quickly by hitting the gas pedal too early in a bend. Im in the UK so temps are lower and running with p zeros which are not the best in the wet or when the temps are lower
I got the base model because I was able to get an amazing deal on it that I could not come close to replicating on the S. That being said if the price difference between the base and the S was similar to MSRP, I would go with the S.
Perhaps the most important option is the active exhaust. In fact, I ended up swapping the base exhaust for the active exhaust and it made a huge difference. In spirited driving an LSD would be nice as the F Type sometimes struggles to put the power down coming out of corners. Adjustable ride would also be nice as well but for the way I use to F Type it is not a must and the base ride is firm but still comfortable.
In conclusion, I think that the reason that you can get a great deal on the base model is because at MSRP it is not worth it. However, when dealers throw large discounts on the base, it does become a very attractive value.
and no, it is not a wrecked nor high mileage car.
Taxes are among others a reason cars like these are hard to sell here when young, loose much value in the first couple of years.
Unless you do not have any problem buying such a car new, there is no point to here.
Might take some time to find the right car - right color, version, specced to your requirements, etc - but if not in a hurry, which I was not, you can make good deals
Do you have chewing gum for tyres lol.
I've never had summer tires so I'll be curious to see what happens when the temps drop.
