Your picture isn't clear enough to let me see if some of those are solid color or have a trace color.
but it looks like, top to bottom:
yellow
grey
blue/yellow (can't see the yellow trace but it would line up with mine if it were there)
grey/blue
yellow/green
white/purple
green/white
blue
I think mine matches yours except for discoloration. I wound the cloth covering on the bundle back a bit to see if I could get better colors but it's just simply hot AF up there and it's discolored back as far as I can get. Right now, my car says it's 50C and my laser thermometer says the black part right above that circuit board is 183F.
looks like all the wires are there and correct except working out the last 2.
Seems weird that the lousy perp would cut your harness.
If he was just trying to disable tracking or whatever he would either have just cut the wire or unplug the connector and NOT both. if after cutting your wire why would he be bothered to unplug the connector that had already been disabled unless all he was after was your connector in the first place. Also why wouldn't he have also cut the other side
??Suggest either malicious intent to you rather than a theft attempt.
yellow
grey
grey/blue
yellow/green
white/purple
green/white
blue
I be back at this tomorrow. Work is crazy. Thank you for the multiple attempts here!
