Pops when changing gear (V6)
I have a MY2020 V6 and nopticed that I only can get pops when changing gears if I do it manually. It's pretty easy, just change gears when you are above 2500rpm. However I saw some videos where the V6 also does this automatically when driving in S and Dynamic however it doesn't work for me. Is this normal? Does it only work automatically if I'm driving it very hard and even then it's not guaranteed?
I know...that comment is irrelevant.
so you're not talking about the backfire/overrun pops, the Fart on upshift, typically known as a DSG fart. my v6s doesn't do it in auto mode S mode really ever, very rarely, but in manual it will do it basically 100% of the time on hard acceleration.
I get less on upshifts if I'm running automatic, but it's reliably farty if I'm pushing at all and use the paddle shifters. (There's no automatic RPM adjustment for the gear change.)
Overrun pops happen in all modes when you back off, but will be a bit more pronounced in Sport mode (because it downshifts quicker than Normal), and even more so when you're using the paddles, since you're in complete control. (And, when it gets too quiet, just drop down another gear and start all over.)
To the OP, you'll should get more noise as the car gets broken in, so don't give up.
GoobeGustafson
12-10-2011 11:59 AM
