Porterfield R4-S Brake Pad Installation & Review
Riding motorcycles for the better part of my life, it's a habit for me to triple tap the brakes when using engine braking for this exact reason. And I find myself doing this in cars when there's traffic behind me and I feel like they may not be paying attention. Read: phone addicted drivers.
... Also relates to another of my pet peeves - the old Split Enz track "I see red I see red I see red". Stopped in a long line of two, three, four lanes of traffic at a red light, and every single one of them (except me!) has their foot on the brake (so glaring red brake lights) and the car in D for Dope, although they know (or they would if they were paying attention!) they will be sitting motionless for at least a minute yet. Whenever I stop at a red light or otherwise in traffic, and I either know for sure or judge that I will be stopped for at least 30 seconds, I whack it in N, apply the handbrake, take my foot off the brake pedal and stretch and relax. ...
JacksonvilleJag (06-08-2020)
It retracts the rear caliper pistons. Otherwise you can't compress the caliper pistons to install new pads.
The following 3 users liked this post by RGPV6S:
Paul champagne (06-08-2020)
Actually I don't think you can compress the rear caliper pistons all if the car isn't put in brake maintenance mode.
#28
Well done conbrash...could have done with your video about a month earlier! You make the anti rattle clip look so easy, bet that took some re-shoots ;-)
I drained all the DOT 4 fluid from my ssytem and filled with 5.1 whilst I had all the wheels off.
I concur with what you say, estimate 50% less dust, however the pads have not bedded in quite yet so there's not 100% contact with the brake disk. Dust is graphite in colour as opposed to black from OEM pads, ad as such looks a lot less as well.
The anti-rattle clip was tame for the filming portion, the other side however came flying off lol.
The different color of the brake pad material is honestly a really good point, I didn't even think about that.
#30
Received 3,259 Likes
When I replaced the stock 326 mm rear brakes with 376 mm nearly three years ago now I tried a little experiment on one of the old calipers once I had them out, and the piston manually compressed. But only by a mm or so, it barely moved. That could have been for any one or more of three reasons:
1. You are correct and the only way to compress the rear brake pistons is to have the car do it for you by invoking maintenance mode.
2. It only had that far to go anyway before it reached full compression as the discs and pads were hardly worn at all.
3. The mm or so it moved was just natural built in slack.
I have a sneaking suspicion that a fully extended rear brake piston can be manually compressed (eg by the old fashioned method of using a G-clamp).
They definitely do not turn/screw back in like they do on other Jags such as the XF, I tried it but no go.
