Power upgrade for v6s(p380)
Hi.
I've been learning about the way to increase horsepower for my P380 convertible.
1. Supercharger pulley + Crank Pulley + ECU flash.
this is what I think is the best way to gain more power.
At this point, I start to wonder why Jaguar doesn't use more optimized pulley for more power? when it's stable.
Any ideas?
https://www.ebay.com/itm/Jaguar-F-Ty...sAAOSwbkVbq7ki
what do you guys think of the product above?
I know VAP offers nice setup(pulley+ECU) but cannot get those service as I live far far far away.
Any ideas?
Received 3,209 Likes
It's now well established (mainly by Lance - Unhingd) that a smaller upper pulley on the V6 is a complete waste of time and money.
As the linked page says, 6% reduction and 15 hp (on the P380) is all you will get and even 15 hp is probably marketing BS.
This is because the OEM pulley is already very close to as small as you can safely go.
A larger crank pulley and tune is definitely the way to go but I understand you can't get the VAP tune where you are coz you have a 2018 model.
And that you have corresponded with Stuart/Chris at VAP and there is no way around this dilemma for now.
I feel for you!
I feel for you!
Thanks Oz,
Right after writing this thread, I am told that supercharger pulley meaning upper pulley is waste of time and money.
Crank pulley + ECU flash is the only best way to gain power.
But as you menioned, because of the country that I live in, that has no reliable expert on this upgrade.
I'm seriously thinking about emigration for this. lol.
The upper pulley actually only offers a 2.5% additional overdrive on the V6. It might offer a bit more torque on the low end when used in conjunction with the crank pulley, but the power starts to drop off near redline because the SC is being pushed beyond its design limits. The upper pulley is also more difficult to install than the lower pulley. All in all, the upper pulley is a big waste of money on the V6 whether used alone or paired with the lower pulley
What year car do you have? If pre-2020 (or maybe it’s 19) the pulley can be done by any competent shop and you can do the VAP flash yourself with the flash tool they provide.
Hi.
Any ideas?
Any ideas?
Thanks for the good infos Unhingd!
I've so many comments from you and it helps.
Understand.
My car is produced in Jun.2018.
P380 standard.
What do you think?
Am I able to install VAP Pulley set with ECU flash?
You told me that I can do ECU flash by flash tools provided by VAP.
Very interesting As I don't at all know abat this.
Understand.
P380 standard.
What do you think?
Understand.
P380 standard.
What do you think?
Understand.
P380 standard.
What do you think?
Given you still have a warranty and your situation, you might try Racechip via Amazon for a no questions asked return window. RC advertise a 74 HP gain for the P380. My dyno experience with a V8 is their 71 HP claim was spot on, but describes the max gain under the curve. Peak gain is more like 50.
I've never installed one on a Jag V6, so I can't comment on real V6 gains.
Pros
- Reasonable dyno gains
- Bulletproof so far
- Decent value
- Removable without a trace
- Compatible with an upper pulley
- Comes with a harness continuity plug that lets you remove the controller without removing the harness
- Configurability is limited to on/off
- Bluetooth support amounts to a remote on/off switch - don't buy it
- Advertised gains are not peak gains but the most HP difference anywhere along the RPM curve. The dyno gains are pretty constant, so its a misleading number. Most tuners do the same thing.
- With practice you can install/ununistall in about 10 mins, but the first install can take a while.
Two runs on Map 7. Base run with the controller removed. All three runs have an upper pulley.
Yes I have a V8 so I installed a smaller supercharger (upper) pulley before adding Racechip. The pulley alone adds 30 HP max and 20 HP peak on a V8. The 508 WHP dyno run is just a SC pulley on my V8 S.
Now he could get a larger crank pulley instead which we know with an associated tune (such as VAP) makes a yuge difference, but as far as I know we do not know if the RaceChip tune "works" with a larger crank pulley at all let alone well. My guess is the RaceChip tune is designed for the stock pulley and a larger crank pulley won't "help" at all or it could even stuff up the RaceChip tune. Conversely you reckon the RaceChip tune works well with the smaller upper pulley on your V8, and as both the smaller upper pulley and the larger crank pulley have the same effect - to increase the SC boost - then the RaceChip might just work with the larger crank pulley on a V6.
Only one way to find out!
But TAEUCK has a V6 not a V8 and as we know putting a smaller upper pulley on the V6 is a waste of time, money and effort.
Since your car was built in June 2018, it’s a 2019 model year. The flash tool will not work. However, if you can store your car for a few months, you could have a local shop remove the ECU (or you could remove it yourself) and you could then ship the ECU to VAP for a “bench” tune. DHL express both ways could minimize the downtime on your car.
I may have misunderstood, but check with him. stuart@velocityap.com
I am selling a VAP pulley. I talked to Stuartt, he said they have a pulley and tune with they're running tool now from 2018 on. ( they just updated their website.
