Pre and post intercooler temps
Here is a plot of a 3rd gear WOT pull I did recently. Top image is with the Legend overlay, bottom is the same plot but without the legend so you can see the full data. The temps all correspond to the Y-axis labels on the right side of the graph.
Hope this helps. Let me know if there are other channels you are looking for.
Compared to my logs you have an extra temp channel. I have iat, which was 18 on the run I'm looking at. Charged air iat which hit 95c, and intercooler iat which was 45c. Those are clearly pre and post IC.
Edit:. I was wrong, I just found the other temp channel, the one your log shows as post IC. It's labeled as Boost Temp Raw in the VAP software and like yours, it's about 10 deg cooler than the charged air iat. I'm sure you just need to swap the labels for that channel and the intercooler intake air temp channel and you'll be good to go.
My logs show 4 inlet related temperature channels:
- Boost Temp Raw - Boost Air Temperature Raw Physical Value*Manifold Top Sensor - Pre Intercooler*
- Charged IAT - Air ChargeTemperature - Post Charger
- Intake air temperature - Intake air temperature
- Intercooler IAT - Intercooler Intake Air Temperature
