Pulley only
Old 07-27-2018, 08:28 AM
Stohlen's Avatar
Originally Posted by V8S
The way metal works is it is elastic below the engineered design limit and plastic above, so every exceedance cumulatively contributes to early material failure. No thank you.
Bahahahaha
  #62
Old 07-27-2018, 08:41 AM
V8S's Avatar
V8S
V8S is offline
Banned
Originally Posted by Stohlen
Bahahahaha
https://goo.gl/images/cnkz9W
  #63
Old 07-27-2018, 10:43 AM
Stohlen's Avatar
That’s a cute little chart! Clearly engineers design specifically to this chart and this chart alone for everything! What’s a safety factor?!
  #64
Old 07-27-2018, 10:59 AM
DPelletier's Avatar
It's a valid question. I think, but no one really knows, the 495 tune was likely conservative to limit risk for early model years. Based on some on ramp criteria, the go ahead was granted to plus up to 550. I would not consider the SVR part of the typical trade space since the owners were essentially asked to fund jag's risk mitigation plan with a truly crazy price tag. So my answer is 550 is suitable to exit the warranty period with little risk, and 495 will substantially extend service life. What's your guess?
My guess is that Jaguar wouldn't offer factory tunes that they believe will cause them problems (both warranty and press). It has been said many times that JLR tested the AJ133 to 700 - 800 hp and the inference is that is the maximum "safe" limit. The extra 5% power that the SVR and P7 have over the R's 550 isn't much of a bump so my answer is 575 should be inherently "safe", though since the P8 has 592 then anywhere under or around 600 is unlikely to cause issues either. As far as service life, usage is more important that hp levels; an SVR driven by a moderate is likely to last longer than a V8S taken to the track every weekend. I doubt very much that the V8S and V8R will prove to have measureably different longevity.
Dave
Dave
  #65
Old 07-27-2018, 11:05 AM
V8S's Avatar
V8S
V8S is offline
Banned
They do, it's core academics for any classical engineering degree.
For our cars we have some good data points for what the OEM engineers consider safe. The first hardware-identical V8s were released at 495hp, clearly for risk mitigation. We have modern SVRs selling with 80 more HP, using a hardware-identical engine, but at a price premium sufficient to pay the OEM warranty cost of replacing a blown engine, and still bag a modest profit. Probably not a coincidence.
  #66
Old 07-27-2018, 11:34 AM
Stohlen's Avatar
I enjoy how your own speculation quickly becomes fact in your mind. You have no idea why jaguar made the decisions they did, and you have no idea what safety factor they incorporated into the engine design. I can tell you as an individual with a “classical engineering degree” who works at a major OEM, that auto companies do not upcharge vehicles to cover warranty costs; that’s a real good way to loose any credibility with consumer reports or JD Powers. You may also notice that from year to year horsepower is always increasing; have you ever thought maybe OEMs are overbuilding their engines to plan for the future so they can keep up/beat their competition? Probably never crossed your mind...
  #67
Old 07-27-2018, 11:59 AM
fujicoupe's Avatar
Banned
A bit off topic, but as a non-engineer and barely literate automotive lover, how is it Alfa pushes 505 HP from a 2.9L V6? My Ghibli put out 345 HP from a 3.0L V6, but I did not like the lag from the twin turbos at all, thus I would give up some HP to have a supercharger instead. Question is: Do turbos inherently offer greater HP potential than SCs?
Totally off topic: As soon as the Guilia comes out with a mid-powered V6 with say 350 HP, I'll be in the market. I won't buy a 4 cyl and don't need 505 HP; besides I like a sunroof in a four door sedan and the Quadrifoglio doesn't offer that as an option because it has a carbon fiber roof.
  #68
Old 07-27-2018, 12:05 PM
V8S's Avatar
V8S
V8S is offline
Banned
Its pretty obvious, though, since there are no engine hardware changes between the V8S and the SVR.
​​​​​That limits it to one variable: the software tune, minus a few carbon bits, to charge someone $60K more. God let's hope that's to cover anticipated warranty repair costs and not just pure ripoff.
  #69
Old 07-27-2018, 12:13 PM
V8S's Avatar
V8S
V8S is offline
Banned
Simple: a higher redline.
Dynos model HP as Torque X RPM/5252
Dyno HP is purely theoretical since work (mass moved some distance) is loosely modeled using RPM, which is obviously not really moving the cars mass. All you have to do to increase Dyno HP is rev the engine higher.
You can increase dyno HP with a red magic marker.
  #70
Old 07-27-2018, 01:13 PM
Stohlen's Avatar
Right... and we’ve concluded it’s not possible for an OEM to purposefully reduce power output in order to offer a more powerful model in the future?
Yes, ripoff indeed. How dare they charge extra money (20k not 60k) for an added tune, new front bumpers, titanium exhaust, aluminum suspension components, new wheels and a completely revised interior over the R model!!! Engineering is simple and development costs nothing don’t you know!
  #71
Old 07-27-2018, 01:15 PM
Stohlen's Avatar
Sure... if you completely ignore airflow, engine/induction efficency and pretend the vehicle has a non-existent perfectly flat torque curve. Or are you confusing these vehicles for electric cars? Sounds like you should just get one of those because that’s exactly what you want...
  #72
Old 07-27-2018, 01:55 PM
Stohlen's Avatar
Youve asked a very complicated question... To just skim the surface; turbochargers are much more efficient than superchargers. Some superchargers can take 100s of horsepower just to spin at peak RPM and that horsepower comes straight from the engine itself, reducing overall efficiency. With this, you can continue to increase turbocharger size without the associated horsepower losses to spin them. Focusing on your example, it’s not RPM but rather boost pressure and engine efficiency that really push the Alfa 2.9L V6. That’s a very complex, modern engine with a dual water to air intercooler setup and electronically controlled turbos that run at high boost pressure to pump enough air through the engine for 500+ horsepower. The F-type and similar big engine cars don’t need nearly as much boost to accomplish the same power/torque figures because of their added displacement, but because you can’t turn displacement off like you can with turbos they consume more gas and are overall less efficient for daily usage.
fujicoupe (07-27-2018)
  #73
Old 07-27-2018, 02:23 PM
Chawumba's Avatar
Another gross oversimplification. I own 3 vehicles with v-8 engines, and they all produce power very differently. My long stroke Tundra 5.7 engine produces tons of torque (550 ft lbs) and is super quick from 0-30 MPH, but my other cars would dust it afterwards. My M3 with a short stroke/high revving engine produces the least torque (360 max) but 600 hp, and at high RPM's really comes to life and out pulls the higher torque tundra. The F type is sort of in the middle. plenty of low end torque like the tundra, and almost as strong at high RPM's as the M3.
If you only focus on torque, you could end up like my Tundra - quick off the line, but then boring. If you obsess over HP only, you get the M3, fun, but you gotta rev it to go. Saying power is simply a mathematical equation ignores all the design parameters of an engine/vehicle design.
"Just increasing redline" is not just changing the software programming, way more to it than that. I doubt my Tundra 5.7 could rev to 8300 RPM like the M3 does without a complete redesign.
  #74
Old 07-27-2018, 03:05 PM
15FTypeR's Avatar
No that is not how a dyno works. The work being done is accelerating the dyno using wheels. Work is work.
  #75
Old 07-27-2018, 03:12 PM
fujicoupe's Avatar
Banned
Okay Stohlen, I completely overlooked the fact that turbos spin off exhaust pressure and SCs off belts or some other direct load on the engine.
One other question for you: Do products like Klotz octane booster actually contribute to performance improvement? An acquaintance swears by the stuff and says he can feel the increase in acceleration.
  #76
Old 07-27-2018, 03:50 PM
V8S's Avatar
V8S
V8S is offline
Banned
You're right a dyno doesn't use
HP=TxRPM/5252
It measures how far the car moved then orders uber eats and times that. Its that new math.
  #77
Old 07-27-2018, 08:09 PM
lizzardo's Avatar
Increasing octane rating beyond what the engine is tuned for does not give more power. If the ECU is reducing power in some way because detonation is detected, e. g. pulling timing or reducing boost pressure, then better fuel will get you back to the rated power. Beyond that, there's no performance gain.
In California, the "good stuff" at the pump is just 91 AKI, and that's not really that good.
My last two vehicles specified premium so that's all they ever get. My previous, which I tracked carefully and did lots of data logging when I was working on open source tuning software was interesting. I couldn't log power, but I got better mileage with mid-grade than regular (which was all that was required) but no further improvement going to premium. I tried going through all three quite a few times and the results were consistent.
Back when MTBE was still in use here, with one of my motorcycles I consistently saw 10% difference in fuel economy between fuels that used MTBE as an oxygenate and those that used ethanol. I couldn't tell about power because once you have more than you can use without tragically heroic consequences, it's hard to quantify. My current version of that probably would make more power with better (96 AKI or more) fuel because it has a "race ECU" programmed by factory folks in San Marino, but the heroism/tragedy ration becomes more unfavorable with zero electronic assistance. As a friend described it some time back, "It's like dinner and dancing with Rhonda Rousey. It's as dangerous as you want to make it."
For the record, MTBE sucks at everything, in every way (corporate profits excluded, your mileage may vary, some restrictions apply).
  #78
Old 07-27-2018, 11:17 PM
15FTypeR's Avatar
HP=TxRPM/5252
Are you this thick-headed about every subject you don't understand?
Putting wrong words in other people's mouths doesn't make them wrong or you right, it just makes you look like you should be on cable news, which I'm guessing is where you learned all of this.
If there any other wisdom you'd like to spread? Should I go back to your sprintbooster confusion thread for more?
  #79
Old 07-28-2018, 05:43 AM
Paul_59's Avatar
Banned
- Completely ignoring the fact that peak engine stress is related to peak torque and not horsepower.
Is this statement not an oversimplification ?
My aim is to gain greater understanding, both for myself and others.
Could you comment on two points:
Peak cylinder pressure whether calculated peak bmep or peak imep will correspond to peak torque however that isn't the only contributing factor to 'engine stress. My understanding is engine rpm will obviously be related to piston speed and more importantly piston / reciprocating component acceleration which can be a significant contributing factor of 'engine stress'
An increase in peak torque, which typically occurs at low to mid rpm will obviously also increase power at low to mid rpm.
What increases peak power in all cases where the rpm of peak power is unchanged is maintenance of high torque (with high bmep)to higher rpm or to be more accurate usually a reduction in the rate of decrease of torque at higher rpm.
All things being equal, which they aren't, if our goal is higher maximum speed we need more horsepower.
If however we want more performance in terms of acceleration the the area under the curve is more relevant than absolute peak power figure and if anyone is doubtful about this assertion I ask you to data log the % time your F Type is operating at peak power as I can assure you it's significantly smaller than many would consider even for skill drivers including F type "ring taxi.
  #80
Old 07-28-2018, 06:14 AM
V8S's Avatar
V8S
V8S is offline
Banned
You still seem confounded and confused about what we are discussing.
Does a race clutch decrease time to distance?
Does AWD improve time to distance?
Do tires play any role?
How about driver reaction time?
It is too primative an understanding of power [work done divided by time required] to think that only what happens inside a cylinder affect how fast a car moved from a to b.
You are the only one who is hooked on something like a sprintbooster increasing engine power to reduce time-to-distance. No one else has ever suggested such a ridiculous thing.
All the OP said was that sprintbooster made his friend's jag astonishingly faster.
You should ask "how?" if you don't understand his friends experience, instead of making up your own fairytale storyline which no one cares about, but you.
Quick Reply: Pulley only
