question about auto trans
While I wait I read the manual. Questions come up. Here's one about about the S trans position.
In other cars the S (for sport) trans position will raise the shift points. That function, however, is not mentioned in the F-Type's manual. Not one word on that. All that's mentioned is the way it changes manual shifting. For example, using the paddles while in S will activate permanent manual operation.
My question: Does S do anything else? According to an instructional video at jaguar.com, in S "the transmission remains in the lower gears for longer." Really? If that's the case, how do you know? Is it explained somewhere, or have you simply noticed higher shift points when in S?
The Dynamic Mode, of course, while in S or D, raises the shift points (if so configured), but I'm wondering about S without Dynamic Mode. How is S different from D (apart from altered manual shifting)?
Thanks.
Thanks.
As mentioned above, the primary difference in Sport mode is a change is shift points - up and down. If you want to manually control shifting on the stick, you need to be in Sport mode. However, you can use the paddle shifters from either position. One difference: If you're in Drive mode and invoke the paddles, the car will automatically revert to normal "Drive" mode when it senses you've returned to steady-state; however, in Sport mode, if you jump in with the paddles, it stays in manual mode. In either case, you can "force" it back to automatic by holding the up-shift paddle a few seconds.
I'll second this. My wife and I have a pattern of generally owning one vehicle big enough to put our dogs in the back and a second one that's a 2-seat sports car. That car has been everything from a Miata to a BMW M Roadster, but has ALWAYS been a manual transmission. Buying a sports car with an automatic was never even discussed.
Jaguar pretty much changed all that for me with this automatic. I had heard good things about it and was looking for a 2015 model still on the lot, so the 6-speed wasn't an option. I decided I might as well test drive one anyway since we both loved the look of the car, even it I had to "settle" for an automatic. I was more than surprised. It's easily the best automatic transmission I've ever experienced and if I didn't know better I'd assume it was a twin clutch setup similar to BMW's DCT or Porsche's PDK transmissions.
I've found using the paddles while in auto mode quite disconcerting. It takes several shifts to get to the gear I want, and I don't know what gear it's in when I start downshifting, so I need to keep my eyes off the road longer.
It's better in dynamic mode, even without sport mode, because it's closer to the right gear.
So it seems that S serves 2 purposes: (a) It changes the functioning of manual shifting, and (b) it raises the shift points. So of the 4 parameters modified by Dynamic Mode (throttle response, gearbox, steering and suspension), it only affects 1.
Now I'm wondering: If you're in D w/Dynamic Mode—therefore with higher shift points—will shifting to S raise the shift points even more (cumulative effect), or do they (Dynamic Mode and S) do basically the same thing to the revs, so that 1 w/o the other is no different than engaging both?
You'd think Jag might have explained this somewhere... nope. Maybe someone here knows.
Frenchy (06-02-2015)
You will DEFINITELY know the difference.
My V6S loafs around town in drive; I'm happy to leave it in ECO mode, quiet in my home town, it gets up into 8th gear as quickly as it can.
That "tiny little switch" next to the shifter: press it for Dynamic and suddenly "this changes everything" and you have a very angry cat. Switching the shifter left to Sport I'm not so experienced with. But you will definitely notice the difference between normal drive mode and dynamic.
In Dynamic I keep the suspension "normal" as I find the dynamic suspension setting a bit to harsh for normal roads; can't wait for a track day...
Dynamic is my normal daily driving mode - with all configurable settings "on." It turns up the exhaust, blocks Eco, and keeps the car in fun mode. I only turn it off if seriously stuck in traffic (fortunately rare). I leave the paddles active and use them a fair amount. I agree it's a bit of a guess as to what gear it will use when you first engage the paddles, but I can generally anticipate when to simply double-paddle. If you're about to get serious, move the stick into Sport. It will generally go directly to a more aggressive gear and the paddles stay active. All 2-lane open roads are for Sport.
Admittedly, almost everything I've ever owned came with a clutch, and driving the e-Type around DC was the only time I wished for something different. I'm pleased to say that the F-Type changes all that. It's a proper gearbox that's fast and fun while letting you be lazy when the mood/traffic dictates.
Foosh (06-02-2015)
Wes Steenrod
09-06-2015 06:52 PM
