Question About Vehicle Features (from TOPIx)
I'm considering a 2017-8 F-Type R-Dynamic (aka V6S) with the following features (of many):
- FORWARD FACING CAMERA
- LANE DEPARTURE WARNING SYSTEM
- REVERSE PARKING AID
- LESS AUTOMATED PARKING SYSTEM
- LESS BLIND SPOT MONITORING SYS
- LESS CAMERA
- LESS FRONT PARKING AID
- LESS CAMERA
- LESS CAMERA
Now for your question. On a Benz the cameras feed the distronic cruise control and will speed up or slow down the car to match the prevailing speed limit. What they do on a JLR is beyond me. The fact that the vehicle in question does not have a blind spot warning system surprises me. I thought that feature was a standard and expected as a steering wheel.
The way these cars are equipped never ceases to amaze me.
The F-Type is the first car I've had with a rear camera and after nearly two years I still don't use it - I'm much more comfortable relying on side mirrors and parking sensors for precision parking. I find the angle of view confuses me about distances, the sensors are more reliable for me.
To solve the vis problem I first replaced the wind deflector with plexiglass, a huge improvement over the Jag mesh.
Next I added an $80 rearview mirror digital display that adds a rear and front camera. It is excellent as it also records a 24 hour loop to a 16GB MicroSD card with a bump sensor to start recording if someone bumps into you while the car is not on. You get 1080P in almost a full 360, plus you can scan up and down by swiping your finger on the RVM display to look almost straight down at curbs.
It's so much better than a backup cam that even if you have one I would highly recommend adding a better aftermarket version. It takes 30 minutes to install and costs almost nothing.
I have used many lane departure systems since I rent weekly, and they were all extremely dangerous but the E-Pace's was the worst, bcs it the emergencyaspect could not be disabled. If a car approached quickly from the left or right rear, it would grab the wheel and swerve you hard into the opposite concrete barrier or car. A disaster of a system. Do not by a car with lane assist or any steering intervention.
Whups, I see you did here: Gotta tell those elves...
https://www.jaguarforums.com/forum/f...3/#post2128143
I told Santa Claus that you were BAD because you didn't include a LINK to the unit.
mbk2015
06-03-2015 07:53 AM
