Question regarding whistling VAP Lower Pulley
What's more concerning; I don't know of any aftermarket pulley that's red either. Which would lead me to believe its not from a reputable company like VAP, Eurocharged, etc. I'm sure that VAP will get you straightened out on the lower pulley set-up, but I question that upper pulley and wonder if that's the source of the failure.
Are you sure the pulley rubbed the intake or was it the belt when it was in the process of falling off? Might explain the whistle. Is the pulley loose? If not and the damage was caused by the belt you might just need a new properly installed belt if there wasn't a hole worn through the intake tube.
When I had a modded upper pulley put on my XFR by Eurocharged, the heating of the pulley to allow it to expand enough to slip onto the supercharger shaft caused it to change color. I think it may have been red. Eurocharged painted it back to black to be less obvious to the dealer techs 😂
Maybe this car had an upper pulley swap before the OP bought it and so the assumptions by Vivid or Eurocharged or VAP got skewed. Sadly not much they could have done, not knowing...
JacksonvilleJag (06-28-2020)
Also, if it was an OEM upper pulley, there is no chance on god’s green earth that it came loose, even from a misaligned or improperly tensioned belt. It is almost certain that upper pulley is aftermarket.
As far as the Intake crossover tube damage is concerned, if the wall has been breached it’s a good time to consider installing the Mina crossover tube.
Well it's definitely been established that I got the wrong offset pulley. What's shocking is that of this moment the dealer is covering the work under (WARRANTY)..
The story is gonna get interesting. They're replacing the entire goddamn supercharger. They wont replace the snout (if it's even damaged).. they never questioned the red pulley. However I'm almost positive they haven't seen the over sized lower pulley yet and **** will hit the fan when they get everything back together and the factory belt doesn't fit. I was terrified of this repair outcome, then I felt amazing for 30 seconds until I remembered the pulley. This is absolutely a repair bill I cant afford. Especially over things that were out of my hand. The tune is still flashed on the ecu as well. I'm guessing they havent checked for that.
What are my options if I cant get them to honor the warranty. I had the car 13 days and obviously bought it with a possible tune and after market pulley already
Moral objections aside, it would seem like you have little to no recourse if you are denied warranty repairs. A component that has been directly (pulley) and indirectly (tune) altered has failed. Proving somehow that these two events were mutually exclusive seems unlikely.
I think a wiser route would be diagnosing exactly the root cause, whether equipment provided or incorrect installation, and pursuing a resolution with the vendor/installer. And perhaps, a reexamination of future modifications. I'm extremely pro-tinkering, but modifying a fairly high horsepower application without cognizance of very possible and expensive externalities seems foolish.
SalsaCat83 (07-03-2020)
If it is indeed the upper pulley, this creates a messy battle between your dealer, Jaguar, yourself and whoever sold you the car since you did not install that pulley.
From what was explained to me from vap is that the engines had two different types of crank pulleys. There was a gray, which has one offset and then a black one which has another offset. It was never explained to me that this was the case before I installed the pulley. No where on the site or the vivid racing site does it say that. My oem pulley was gray. A black pulley was installed. So obviously putting the belt on a different offset than the the oem setting.
The tech at the dealer is either being cool about the upper pulley or is inexperienced and didn't catch it. However it will be impossible to miss the oversized bottom. Especially at belt install.
I was hard on the car for the first few hundred miles before the lower pulley, with no problems. I was hard on the car after the pulley install. Then that whistle showed up and and later that night the belt slipped and ripped. One can safely assume it was only a matter of time before the wrong offset yanked that belt off the top pulley. Or else offset wouldnt matter correct?
#30
#31
I can tell you from my personal experience of twice installing a VAP SC belt/crank pulley (the first because VAP sent a belt that was too long and slipped, the second to install the correct length belt I sourced myself) that it is VERY, VERY easy to not install the SC belt on the SC snout pulley correctly since it tends to want to slip off toward the intake tube when you are threading the belt over the other idler pulleys, tensioner and crank pulley. Both times after I got the belt on completely and over the tensioner I had to reposition the belt on the SC pulley because it slipped one or two ribs toward the intake tube during the belt threading process. The point here is if the installer wasn't careful the belt could have started off partially off the snout pulley regardless of the crank pulley offset.
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1040x2000/received_213747089685563_059c829386a6b48b508703a8c48a09e83ea58161.jpeg)
I sent to my installer, earlier that day when i heard the whistle
#32
#33
Or I would've just settled for the (lower hp) snout pulley and tune setup like I had with my last supercharged xkr's. Or even just a tune and lived with the 605 bhp
In regards as to what failed? Aftermarket pulley or not. The car ran fine and didn't whistle with the gray oem crank pulley, and ran fine for the first few days with the vap pulley. Until I really started playing with the car
#34
Not sure if you're not reading my comments or just ignoring them; however as I said before, a wrong pulley offset isn't going to pull the pulley off the snout. Most people destroy the supercharger pulley trying to get it off because its on there so tight. An incorrect offset would either throw the belt or provide a side load to the snout which could do damage, but it wouldn't rip the pulley off. Who said you had an incorrect offset and what proof did you have of that? Why aren't you focusing more on the clearly not OEM snout pulley?
Keep in mind; the VAP pulley color is irrelevant here; the stock pulley is either gray or black... just because the VAP pulley was black, doesn't mean you got the wrong offset. Pretty sure they don't even sell a gray one; its either silver or black. If someone told you otherwise, that's a different story, but I'm still not convinced the lower pulley has anything to do with anything.
"XXX point" inspections are a joke. They aren't looking for tiny things like the wrong color pulley being installed. They're looking for obvious issues like leaks, worn parts, etc. and that's if they even actually do the inspection at all.
#35
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200626_214918_106f2826a3330abdaacd0ca27bd52030e53787c8.jpg)
I'll explain it the best I can..
This is a pic of the shredded belt before it fully ripped off trying to move it away. It's pretty obvious it pulled forward just enough to yank the snout pulley forward. Hell for all I know, I got the wrong belt size too. Which gave it its room to elevate and hop forward?
The wrong offset pulley info was told to me by Stuart at Velocity himself. The pulley colors are on purpose to match the two different oem pulleys. Does that satisfy you?
I did many hard 40 pulls with the car at 4k rpm in 2nd gear with the stock crank pulley learning the rpm and sound in cohesion with the dash gauge to get my 40 roll reaction times down. No issues..
I did ONE ! with the wrong lower crank pulley and I heard a loud screech and found the belt like that when I pulled the car over. Do your due diligence and ask vap yourself. They said the pulleys have to match color. Apparently a system so unknown even forum experts like you were unaware let alone me.
You tell me sir. I've been reading knowledge for you Cambo, Unhingd, etc on and off for a long time. You're the experts and I absolutely mean that with the upmost respect.
#36
#37
I 110% agree..
As far as the damage?
I'd be willing to gamble that the snout was salvageable and my dealer saw the word warranty attached to my car and went wild. Maybe the pulley and the bearings needed replacing. Worst case the snout too. Jaguar of course does not replace those parts, or the snout. The whole supercharger has to be replaced.
My worry is that they do the work, apply a belt, it doesnt fit. They do some investigating and see the crank pulley is too big. Now none of it is warranty anymore and I'm left with a 9k bill for work done, and not the 600 dollar rebuilt snout replacement, along with a new belt. I could've done elsewhere for 1/8 the price. I doubt I can say screw that. I want my old eaton, I'll buy a refurbished snout/pulley and have a performance shop do it.
I'm in a tough spot because They may also just say **** it and buy a bigger belt or just day **** it and replace the lower pulley with an oem.
All with the bottom line that this was all caused by the wrong lower pulley being sent to me. I'll know in a day or two. The new Eaton is coming from Atlanta as of last Wednesday. I'm in NY..
ps.. I truly gave the car its runs with the off the lot setup. No problems
#38
I don’t understand why the dealer won’t just replace the snout. It’s available brand new for $570.
https://www.jaguarparts.com/oem-part...Y2LWdhcw%3D%3D
#39
No way in hell the belt ruined the rest of the blower.
My dealership is awful btw.. They survive selling base model xe's and landrovers to survive. They cant keep techs or service writers to save their lives. You never get a human. Only a voicemail, and I begged for courtesy car asap. Not a word. The car has been gone 11 days.
I'd assume the service department is trying to make some money with easy mechanical warranty work?
I'm an idiot and only speculating.
#40
