Quick help needed - was there a TSB on the diff ('16 R, USA)??
My poor car is back at the dealership yet again for the exhaust whine, but had also developed a thunk in the rear with low/light throttle application and release, as well as a distinct grinding noise from the rear at 1500 under load. Sounds like a diff issue to me, but what do I know.
For context, the diff sounds started in October, when it was hot out, but couldn't get it in for service until now, when it's currently below freezing. It's still under warranty, for another 3 weeks.
The advisor informed me that the thunk and grinding is because I don't have winter tires on the car. Said "without having winter tires on the rear diff is locking and the traction control is trying to keep the tires from spinning which is where the grinding noise is coming from. Winter tires are $1924.00 installed."
Before I take off my earrings and ask a bystander to hold my purse, I want to make sure there wasn't a TSB or something that I can hand to them and ask them to look at. I vaguely recall reading other reports of diff failure on the forum over the past year of research and for some reason I am also remembering a TSB on the diff? But I could be wrong, so just want to make sure.
Thanks all.
Thanks all.
I don't appear to have anything related to diff issues. Here's a clunk related to the transmission output flange, which doesn't sound like what you're describing.
https://www.dropbox.com/s/lec9xkk5vo...402V3.pdf?dl=0
Haha, yes, my husband suggested the same thing. I don't think that quickly on my feet, unfortunately! And despite the satisfaction of eventually proving them wrong, I cannot stomach paying $2k USD for a set of winter tires.
May well not be your problem, but everything I have read (except from scm, above) indicates that the oem Pirelli P-Zeros and other Summer tires are unsafe below 45 degrees.
They become hard and brittle,and may crack. They provide poor grip in the cold and can be deadly in snow and ice. Considering where you live I am sure you get very cold, icy, snowy weather in the Winter.
My solution (in Boston, MA) was to fit all season tires. A set of Michelin PS A/S 4's cost about $1,100 fitted and balanced - not close to $2K because they were not fitted by a Jaguar dealer.
So, my advice, for what it is worth, is that if you intend to drive the car in the Winter, you should definitely get a set of AS or Winter tires. You should get them fitted somewhere other than your Jag dealer.
Forget asking for a refund from the dealer. You really need the tires regardless.
Then you can determine whether there really is another problem
My next request was for a quote for the diff to be flushed and filled. I figure at least I've made my best faith effort to allow them to resolve the issue, and if the diff fails in the near future, at least the issue has been thoroughly documented prior to the warranty expiration. I can't imagine if they do find some metal bits on the plug or gunky fluid that they would just drain and refill and call it a day. I hope.
Bryan Pedersen
07-14-2020 05:19 PM
beady
08-25-2017 09:28 PM
Bacardi 151
03-23-2012 05:07 PM
