Quiescent Relay Fusebox
This is part # C2D23644. There is a relay integral to the fusebox near the battery that shuts off the infotainment system if the battery management system feels that the battery is low. This relay tends to stick closed. In my case, it took 20 minutes after I turned on my car for the touch screen and all functions to turn on. Once on, it worked fine for the rest of the day. You cannot replace just the relay but the fusebox is about $150. Online. It’s plug and play. It’s possible that if this relay is stuck on, it could drain the battery.
Sabrinaservicewriter (06-14-2022)
Are those white relays (marked B) soldered-in or do they plug in? ![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Nevermind, I found that they solder in. Only $2.71 each.![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
Hopefully this will help other owners in the future!! Contact information at the bottom of the page below, in Chicago USA and Leeds in the UK.
https://www.newark.com/te-connectivi...vdc/dp/96W3601
These are interesting relays. Biphasic latching relays. Can latch on or off. Also the fact that there is one for + and one for - gives a great deal of flexibility. You can shut off all components run from this fuse box by latching off the + relay but latch off only those that don’t have their own grounding by latching off the - relay. So major power users and minor power users separately.
ddisme (12-27-2023)
hey guys i have land rover velar 2018 Rdinamic i have big problem with this velar, i get System SOS limited functions, and i get B1412-96 this code can someone help me please i will paid for your time but help me to fix this issue in my velar i can't control air and others funtions
Tell me, where exactly is it located? To replace
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
