R Coupe rear brake calipers....
Hi guys,
i am trying to find a solution for the car's unatrractive single-piston floating rear caliper design. In my opinion it doesn't look good because it looks puny when compared with the large front calipers. I contacted Stop Tech and I found out they dont make BBK for the Jaguar F Type. Not enough demand to justify making brakes for our cars. I was also told Brembo does not offer brakes for our car. I was hoping to swap out the stock rear calipers with an aftermarket 4 piston caliper so it appears cosmetically better the OEM rear brake calipers.
Your thoughts please.
Thank you.
Thank you.
Lizzardo makes an excellent point. This document shows how the EPB actuator interacts with the rear calipers.
https://www.dropbox.com/s/uajlxghl1a...brake.pdf?dl=0
Unhingd (12-15-2016)
I wouldn't do it for looks either, but the cost to get what I want is probably prohibitive for me. I just find it irksome that even the "Super Performance" option didn't come with opposed piston calipers.
Those are 398/380, where the Super Performance are 380/376. That seems within the realm of possibility, given proper mounting brackets.
getting brackets made is the easy part. i've been casually looking at upgrading the calipers for a while now, but getting the information needed to try to piece together a solution has been tough
I have the OEM carbon ceramic brakes that came on my R and I can confirm they are made by Brembo specifically for the F type according to my service advisor. I can also confirm they squeak like crazy. They look amazing but the squeaking just doesn't suit a car I paid $125 K for.
