R Supercharger Details
Hello, I'm new here. I've been lusting after the F-Type R and it has now led to me seriously thinking about pulling the trigger and buying one.
My question is...does anyone know where I can find more detailed info on the supercharger that's on the V8 R? Is it a twin screw? Roots? And does anyone know what PSI it runs at?
Welcome to the forum, when you get a moment stop by our new members area ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
It's an Eaton TVS R1900, OEM version. Probably running about 9psi or so.
Wilkommen
Wilkommen
Unlike the supercharged V-6s, which use Bosch engine management, the Jag V-8 uses Denso engine electronics. A 9.5:1 compression ratio squeezes 1.5 bar (21.75 psi) of boost supplied by the V-mounted Eaton roots-type twin-helix supercharger. The V-8's bore is 92.5 mm and stroke is 93.00 mm, making it essentially a "square" design. Four valves per cylinder help pump the air to generate the V-8's 495 horsepower and 460 pound-feet of torque.
2014 Jaguar F-Type V-8 Engine Technical Details: 30 Days Of F-Type
That's for the V8S
That's for the V8S
Atomic (03-22-2016)
These twin vortex Eaton superchargers are classified as Roots blowers, but they look more like screw-type to me:
Roots Superchargers
Anyone know why? I guess it's sort of a hybrid?
The technical specs say it is air-to-water intercooled....does that intercooler sit off the engine somewhere for heat management or is that the slim set of "wings" sitting on either side of the supercharger?
Roots Superchargers
![](http://images.thecarconnection.com/hug/jaguar-aj133-gen-iii-5-0-liter-supercharged-v-8_100425595_h.jpg)
Roots Superchargers
Roots Superchargers
Thanks for the info on the type of charger on the F-type. This is a roots blower. In the past, I've built Mustangs with Kenne Bell twin screw chargers. I really love supercharger cars. Always had a thing for them.
Also, the TVS is a roots, but it's very different to the old M series.
TVS is a 4-lobe rotor with a much greater twist in it, the performance of the TVS is getting closer to a twin-screw, & is miles ahead of the old M series with 3-lobe rotors and a slight twist.
The following 3 users liked this post by Cambo:
I think it's still classified as a Roots supercharger because the screws turn at a 1:1 ratio and the threads are evenly spaced, i.e. air is not mechanically compressed as it moves through the supercharger. With a proper screw-type supercharger, the air gets compressed by the screw design or the twin-screw drive ratio.
Cambo (07-25-2014)
The XF/XK owners on this forum have measured between 7-11 PSI on their cars, depending on the tune in them. No way is the boost anywhere near 21.75psi, not a chance. The older 4.2's were 8:1 with ~13psi, the 5.0 with 9.5:1 will definitely run less boost from the factory. 21.75psi is probably an absolute measurement on the 510HP engine (14.7 + 7) and the 550HP tune is around 9psi. The cars that have been tuned by ETG or Eurotek have gone up to around 11psi.
I used to own a VW G60-equipped car (actually make that 2 Corrado G60s), and still own an R53 Mini Cooper S Works - so I see where you're coming from with supercharger whine.
FYI - if you use an Android phone you can purchase a bluetooth adapter ($11.99) that plugs into the OBD II port. Download the Torque Pro app from the Play Store ($4.99) and you have the ability to display a bunch of real time engine operating parameters on you phone, from cooling to supercharger boost psi and dozens more.
Amazon.com: Simvalley™ Mini ELM327 Bluetooth OBD 2 Automotive Diagnostics Scanner for Android: Automotive
One thing to keep in mine if you use the cheaper OBD II adapters is that they draw power all the time and will kill your battery if you leave it plugged in and the engine isn't running.
There are more expensive adapters that will auto shut off. So you can leave it plugged in. The one I bought is a OBDLink MX OBDLink MX Bluetooth | OBDLink You can also buy it at Amazon.com. There are probably other out there that auto shut off. Just be careful.
golfhero (08-07-2014)
So the OBDLink MX auto shuts off?
Do you know if it monitors oil pressure and/or oil temp?
The biggest frustration I have on the F-Types is the generic temp gauge, which is going to likely be more about water temp (gets there faster, in my experience) and not terribly useful.
If so, then I would guy an android tablet, link to this, and just leave it in the car as it would be useful.
Yes it does auto shut off.
TorquePro and OBDLink's own software show it will read oil temp but not oil pressure, But that depends on whether the car has an oil temperature sender. I need to play with the app more to see what it will do on the car.
A lot of cars have very heavily buffered temp gauges that are not much more that idiot lights. Reading the temp from the OBD adapter should read raw unbuffered data.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
