Rain Mode
Maximum wet traction with the p-zeros might be good, but when they let loose, it's like falling off a cliff. The PSSs will give you plenty of notice they are on the edge and will give you the opportunity to reign things back in again.
I finally used the Rain / Snow mode. It's fascinating. It turns the car into a Hyundai. I joke I joke... but it's obviously drastic.
What sort of weather are you actually using this? Heavy downpour, or even when the roads are wet? What speeds are you driving on wet roads in these p-zeros?
Might be useful on snow and ice, but not much else. When the roads are plenty wet I leave in normal mode, but in fair weather use TracDSC when I'm in the twisties. I can't speak for the p-zeros, but at legal (or slightly more) speeds,no need to throttle back on the PSSs in the rain except in tight turns.
rain/ice/snow mode optimizes stability of the vehicle
to suit low-grip conditions. This helps the vehicle to
perform in a more gentle and controlled manner to
avoid skidding, allowing more confident progress
under adverse conditions.
Rain/ice/snow mode as part of the dsc uses:
• modified slip-control system map for braking
• decreased throttle progression
• early transmission upshifts
• softer damper map (adaptive damping variants)
Winston Gilbert
02-11-2016 02:32 PM
Rhett
11-21-2015 10:23 PM
