Ran out of gas!
I feel like an idiot but I have an excuse. Just driving normally a couple days ago, made a right turn, and the engine slowly died. Luckily I was able to coast to the side of the road out of traffic. The idea of running out of gas occurred to me but I quickly dismissed that because the indicator on the dash said I had 15% fuel left. I tried to start it a couple times but it would just turn over and nothing else. So I decided there must be something fairly major going on and called for a tow. They sent me a text saying they would come by in 1 1/2 to 2 hours! I then noticed there was a gas station just across the street and I thought oh well, I guess it’s worth a try. I was able to get a gas can and added about 1 gallon. After a couple attempts my cat roared to life. Yes! I cancelled the tow, filled the tank, and it was running perfect again - except it now had a check engine light. Once I got home I put the code reader on and it said there were several “generic” codes such as P008A. Not sure what they meant but I assumed they had something to do with running out of gas. I cleared the codes and everything seems back to normal.
So my question is - has anyone ever run out of gas when the gauge said you still had fuel? I realize I shouldn’t let the car get so low on gas before refueling, but I was running late. Anyone ever experience this?
You should read the manual about how to restart the engine safely after running out of fuel. I know, because I did it too. I’ve decided my fuel gauge has always been defective and never went below about 45-50 Miles til Empty. It now doesn’t even go below half a tank, ever. I use the trip odometer to keep track of when to refuel.
When you run it dry, it needs close to 2 gallons to prime the fuel system. Give it at least that, turn on the ignition (but not the engine), and let it sit for 5 min. Then start the engine. For me, it started immediately.
cujet (11-13-2022)
