Rattling in the transmission tunnel?
I have this annoying little problem when attacking the back roads. Emphasize on that because it apparently doesn't happen unless I drive it hard after a while, assuming the trigger for the rattle is a hot environment.
When I drive the car hard after a while, and make high speed left turns, I can hear this rattling noise somewhere under the center console/transmission tunnel. It sounds like little rocks hitting a heat shield. However, I took a look under the car and I couldn't spot anything that's loose or may be hitting the heat shield. So maybe it's something directly under the shifter area? That's the closest I can pinpoint it. Anyone else know what I'm talking about?
Received 3,220 Likes
Maybe it really is "little rocks hitting the heat shield"?
This is a reasonably common thing with XFs - small rocks, pebbles, bits of gravel etc get up under the central tunnel heat shield and make a helluva racket.
In your case it could be that when cold the heat shield is "shrunk" and the rocks are jammed, but once you get things good and hot the heat shield expands enough for them to start rattling around.
Try getting underneath when things are warm rather than hot and tap the heat shield with something reasonably soft in a few places and you might just hear your rattling rocks.
If you do, remove the heat shield and see what falls out!
MisplacedPriorities (07-28-2020)
I still can't figure it out, so I recorded it, hoping someone can help me diagnose. It's actually happening more often now, even from just short periods of normal driving.
Ignore the constant rattling in the background, it's a trim piece I think...haven't pinpointed that either. Listen for what sounds like a wiring harness tapping on metal, especially towards the end of the video. That's what bothers me to no end. I know for certain the sound isn't there on idle or driving on smooth surfaces, so it only sounds off when a force is exerted on the car while driving. It also shuts up when I turn right; I believe the force from turning right forces whatever that's rattling to move away from whatever it's rattling on.
https://youtu.be/RNISikwsmqQ
I did...tried banging on the heat shields and playing with it, but I can't reproduce the noise. I might just have to take the whole shield loose and see if there's anything beyond it.
n2audio
07-23-2016 08:43 PM
