Ravenol oil
Ravenol oil
Anyone used this oil before ? I was thinking of buying this kit. Car no longer has warranty, so not concerned about the dyed Castrol stuff, if this oil is fine
https://www.blauparts.com/jaguar-f-t...t-30l-rwd.html
No idea about that one, but I used this one, with the recommended oil.
https://www.roverparts.com/Parts/OCK...iABEgLhUvD_BwE
magredvet (11-05-2018)
Received 3,259 Likes
I have re-used the OEM drain plug several times across the XFS, XFR and F-Type without a single problem. I even have the OEM XFR plug (over eight years old) on the F-Type at the moment, the reason for that is the OEM F-Type plug had a fair bit of silicon sealant on it which was difficult to fully remove so I swapped it out for the perfectly clean XFR plug which I had replaced years ago with a magnetic plug.
They are all the exact same plug and all you need to do is check the thread and the condition and fit of the rubber/plastic sealing ring and if they are perfectly OK you are good to go.
Carbuff2 (11-05-2018)
orangeblossom
02-28-2016 04:35 PM
jagosaurus
01-10-2013 12:55 PM
