Rear 3rd brake light not working.
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
I have a 2016 Jaguar F Type S AWD Convertible. The third brake light under the spoiler does not work. I have removed the light, and it works perfectly testing with a 12 Volt supply. There is no voltage getting to the light and am looking for some help in resolving this. I have downloaded the manual and can see that the power comes from the Central Junction Box. If someone could direct me to where this box is located, I would like to check the output from it and also trace the cables to see if I can find the problem. Any help or suggestions would be greatly appreciated.
Stubbsy,
I had the same symptoms on my 2014 F-type V8S convertible. Here is the verbatim diagnosis that I got from an Indy mechanic. It should give you some things to test out for yours.
"Scanned vehicle and found code b1115-14 high mounted stop lamp malfunction. Removed brake light to check for power. The brake light is not getting a signal when pedal is depressed. Brake light works on a signal from the body processing module located in the cjb to supply power and has a fixed ground. Checked the ground wire- tested good. Removed carped trim on the passenger side floor to access connector c3bp01a pin 8 going to the central junction box. Tested wire from connector to the 3rd brake light- tested good. Both wires going to the brake light tested good and no signal is being sent to the brake light. The cause looks to be the body processing module which is internal to the Central junction box. Central junction box must be programmed by a dealer scan tool."
Stubbsy,
Hi. I looked under the passenger footwell and there is no cover or anything that looks like it could be the CJB. Also looked under the driver's side and could not see anything however this is difficult due to the foot pedals interfering with the carpet..
Do you think it is possible that they moved this in later models?
Carbuff2 (03-06-2024)
randyb (03-10-2024)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have found that there is no power going to the 3rd rear brake light. With previous help I have now located the Central Junction Box (CJB) and now need to access the connector C3BP01AR which is underneath the junction box. How do you access this as it is underneath the large connector C3BP01CR. I need to do this to access pin #1 to test for voltage output and continuity of the wire to C34l
coolhotblue
05-29-2012 05:17 PM
