Rear Camera Cable
I recently purchased an F Type R. I noticed that the backup camera was not working so I took it to my dealer. They said whoever changed the battery accidently cut the camera cable. The dealer says they have to replace the entire harness from the trunk to the dash and labor alone is $4750. Seems like I should be able to just find the cut wire and splice it. Anyone have any opinions on whether that should work?
art.vandelay (10-21-2020)
You are correct. I got the car back today and sure enough, someone pinch the cable with the battery tie-down and snapped it. I snipped off a piece of the cable and it's coax or fiber-optic. Either way, not looking good as far as an easy fix.
If it’s a fiber optic cable, a splice or connector will not suffice. It will require a powered junction box. Your local Verizon Fios technician could probably get you sorted for a lot less than $5k.
