Rear Diff drain and fill plugs - white sealant?
I’m doing an oil change in the read differential (thank you ‘TheRock’ for the procedure!) and found that a white sealant was used on the plug threads at the factory. Should I clean and replace with new, or perhaps use Teflon tape? Does anyone know what the sealant is?
thanks
steve
thanks
steve
I was tempted to do the same, and appreciate you relaying your experience. Not worried so much about leaks as I am about a ferrous drain plug in contact with an aluminum housing. So, at the very least I'll use Teflon tape, as I have done so with classic cars for many years, with good results. However, I came across Permatex Aviation Form-a-Gasket Liquid Sealant, which is also impervious to oil. Has anyone had any experience with this?
Done same to one I had , could always slap a bit of grease round plug threads but other than that dudes way to fussy
For the record, I didn't use anything on mine either, but if I had it would have been teflon tape. I would not use any "form-a-gasket" type of sealer as I'd be concerned with it setting up too much and making removal difficult the next time. I just went through an unpleasant situation where pipe doe had set up too hard on some plumbing. Changing a utility sink faucet turned into tearing off the backsplash, cutting into the drywall, and replacing some piping just to achieve the original goal. I still need to grout the new backsplash ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Anyway, it's a tapered thread so it wedges in place, and care needs to be taken to not overtighten.
SteveHall (12-15-2022)
thanks
steve
thanks
steve
When applied looks just like the factory stuff.
When I changed the diff oil in my car I just bought new plugs. They are very cheap. They come with the sealant on them already.
