Rear Differential Fluid Change DIY
Hi Group...
After publishing many DIY articles/documents on the various Porsche forums, I thought I would do the same here on this forum, to the extent they are useful and/or helpful.
Cars are my relaxing hobby, when I have the time. So I enjoy learning about them and modifying or fixing them. For the last number of years, I have been doing that in the Porsche and BMW forums/communities,
so I thought as I tinker with the F-Type, I would document some of those items here with my new Jaguar forum friends as well![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
So, while cooped up due to this lovely Bat/Pangolin disease I did some work on the F-Type. First up was front and rear Differential fluid change. I took some photos and documented the process, and put them in my
DIY template. I have attached the Rear process, and will likely get the front posted soon...as time permits. The Porsche forums found these useful so I continued to produce them. If not useful, I still photograph and document for my
own records.
These are created in the spirit of helping others. If you have a better way of doing it, knock yourself out...this is simply what worked for me.
DC
own records.
DC
The following 22 users liked this post by Therock88:
andykreb (03-28-2020),
bcbruno (04-11-2021),
blgN8 (10-18-2022),
BONESTOCK (12-17-2022),
David Meier (07-07-2020),
and 17 others liked this post.
Love it! Added it to my F-type doc repository on Dropbox, let me know if you’re OK with that (which seems likely.)
https://www.dropbox.com/sh/wgv3e86yc...glFoM3xOa?dl=0
The following 2 users liked this post by DJS:
Thunderjet Racing (05-13-2023),
winstonsalemncxk (04-05-2022)
Hi Group...
own records.
DC
own records.
DC
DC
Panthro (12-22-2023)
Well done...much appreciated.![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
I've used the IV type fill procedure on our other cars (one of which has a 2-year or 30K rear diff fluid interval). With this method, you need a plug for the IV tube to prevent messy spills. A proper sized bolt does the trick as long as you have it close-by when its time to withdraw the tube.![Icon Idea1](https://www.jaguarforums.com/forum/images/smilies/icon_idea1.gif)
Those cheap fluid pumps only seem to work two or three times no matter how well you clean them. I've taken to having new ones on hand to prevent frustration.
Take care,
DC
Agree on those pumps too. I actually have a better electric fluid pump, but it would not pump it. Something screwed up in the pump mechanism. It would run....but nothing moved. Even tried on thin fluid...no go.
DC
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/510x526/1s_033f51dd02af0070d8ddad1d375947c73d105023.jpg)
@Therock88 Really useful writeup ~ thank you.
One area thst needs changing though to save any confusion....
These diffs require a set quantity of oil and therefore don't fill to the filler mark as you would on a conventional straight diff.
I'll try to get the info, if memory serves me it's 1.2L wet.
Thanks,
DC
Vehicles with 3.0L petrol (340 PS) SAFXO Dry Fill 0.84 - 0.86 Wet fill 0.815 - 0.835 Liters
Vehicles with 3.0L petrol (360 PS) Dry Fill BOT720 0.84 - 0.86 Wet fill 0.815 - 0.835 Liters
Vehicles with 5.0L petrol BOT720 Dry Fill 1.24 - 1.26 Wet fill 1.200 - 1.220 Liters
The following 2 users liked this post by Therock88:
I like it, and it has been very useful. Only challenge is if you need access to the center of the car, but I have extensions that help with that too. It has worked for most anything I have needed to do.
Take care,
DC
Thanks for the write up, I appreciate it. what does wet vs dry fill mean?
Dry fill is the amount of differential fluid needed on a new (or totally rebuilt) unit.
But, Wet Fill is the amount you need when draining the differential in the car. There is always an amount that remains, you can't get it all out.
SS4PK (03-31-2020)
Take care,
DC
Hi Group...
own records.
DC
own records.
DC
I have recently purchased my Type F R with 20k miles on her.
So I will be doing these two fluid changes myself very soon.
I have not seen any DIY for the transfer case fluid change.
Would you be able to post this for everyone.
Much appreciated.
Thank you for the great DIY for both the front and rear diff fluid changes.
Much appreciated.
Much appreciated.
DC
The two you posted are for the front and rear diff.
Thank you
DC
