Rear diffuser
There are only about 6 bolts, ~3 on each side. Then it just slides out the back. Just slide under the car and you will see them, with a little looking. If you have a replacement diffuser then you can see right where the bolts are. The hardest part is just getting the trim pieces around the exhaust moved to the new diffuser.
I have base FType, 2016 with center pipes. I love the look of the diffuser but rather than replacing the entire rear diffuser wondering if there was a 'classy' looking aftermarket add-on perhaps one you can stick on with 3M that gives it that look ?
Here are two pics of my F-Type for reference
