Rear end oil leak
Originally Posted by Arne
Sorry but I do not know. Had my seal replaced with a new one last week. Unfortunately after driving some considerable (and fun) distance over the weekend, there still seems to be a minor leak present.
Car going in tomorrow for further "investigations".
Edit: car is checked for leaks and the diff and pinion seal is 100% sealed and thight. What I thought was still a leak, was most probabely some "leftover oilspill" from the previous leak, that had ended up at places which he (the mechanic) was not able to reach. Some active driving in curvy mountain roads in very warm temperatures made the "leftover oil spill" move from were it was collected.
Thanks for the advice Nati, and I will. However I did drive some 320 rather "enthusiastic" miles after the seal was changed over a 3 day periode up Mountains and through curvy fjords. I did deliberatly park on "easy to spot oil leak" surfaces during the whole trip and it was only during the two first days that I did find some oil drip. For the last part of the trip, and over night after I came home, there was no oil drip to be found. The mechanic also checked the oil level, and the diff was 100% full.
All signs indicates the leak has stopped and was caused by the pinion seal - but I certainly will keep an eye on it.
#33
is there anything to consider when disassembling the servomotor? Can you get it back together, or is there a specific installation method on this motor? My rear differential is also slightly damp, and would like to reseal this. I'm just a little concerned about the servomotor in case I have to disassemble that as well.
Thank you so much for all answers
Andi
#34
Hi,
Andi
Andi
#35
So you can rebuild the actuator Motor in any position? Even if the differential was rotated after removing the actuator Motor? At the moment it is not yet clear where the oil is coming from. Looks more like the case or the transition from the aculator motor to the case.
#36
#37
#38
What is the case sealed with? Standard sealant or are there original seals for sale?
Thank you
BR
Andi
orangeblossom
02-28-2016 04:35 PM
Bacardi 151
11-10-2015 11:26 AM
wotcham8
06-05-2013 03:24 PM
