Rear hatch liftgate struts not closing or lowering
For the life of me, I can't seem to find a relevant thread or post about replacing the rear liftgate struts. There are some similar posts but nothing helpful. I'm posting from my phone, so it may be the format of the forum that is making it more difficult for me.
Anyway, I'm trying to find a way to remove the struts and install the new ones. JLR wanted to charge me $1400 to do it. I'm mechanically inclined, so I told them no. If it was $140, I might have said yes. Does anyone have tips and tricks to replace these struts? I was able to loosen the clip (last photo) and pop off the strut from the ball head.
Any help would be greatly appreciated. I will post here with more photos and write up a DIY set of instructions once this project is finished.
I am sure you have check fuse right, there is also a module mounted over the fuse box that controls the trunk hatch.
Here is one online that would be a cheap you could give a shot before replaceing the actuators.
I didn't check the fuse. Are there actually separate fuses for the liftgate even though it still opens when I hit the buttons? I don't have to manually open it, but I do when I close. I'll see if I can't find the fuse box and check for a fuse issue.
Silly me that I trusted the dealership when they told me it was the struts. I'll have to chat with them if it's just a fuse.
I put no faith in what a dealer says. I had obvious noise in my audio system that the dealer conviently said was not there. I guess I should not believe my lying ears since the dealer said everything was fine. That is what sent me down a rather expensive rabbit hole replacing 99% of the factory audio system. If it were mine I would try the module. If it worked then cheap fix if not you could always resell it.
I'm having a hard time finding replacement struts for the rear lid. Several sites advertise their struts as rear lift gate supports or struts, but I've ordered from 2 different sources and both were mistaken. I'm at a loss. I have yet to find the fuse box for the lift gate.
You seem to suggest from what I have read is you can open the boot with the button but not close it ???
if so it can’t be the fuse so don’t both looking for it as there is obviously power going through
Correct. I can use the FOB or the dash button to open the hatch, even though it opens slowly. However, it won't close if I use the button on the lift or the FOB.
How’s your battery condition?
I had trouble with the lid opening and closing like you.
JLR replaced my battery under warranty last fall, and this problem got fixed along with some others.
No surprise there.
