Rear quarter light screw?
Hi All,
Quick one - Can anyone confirm if this rear quarter light screw should actually be fully extended rather than screwed in (you have to pull off a small rubber cover to get to it). See pic below where it is currently screwed in as far as it will go but not sure this is correct.
Thanks all
Jo
Thanks all
Jo
Don1954 (09-12-2018)
@ Unhinged - reminds me of my own recent question on where a rubber piece I found in the car should go.
On the right I think to see the end of the right side rear window, and that open spot were you see that "screw" is where my rubber half moon shaped piece of ribber had to go - don't you think?
Unknown part
And, I think it should be this way... I'll have a look in mine.
Unknown part
Just looked at mine. To my eye, it appears to be an adjustable spacer that is bonded on both ends. I would guess that it is to adjust the position of the rear of the rear glass, i.e. depth of mounting relative to outer skin. In the pictures, the driver's side rear side glass is on the right and the adjustable mount (I'll call it that for want of a better term, but would not try adjusting it now because I think it'd break the glue loose) goes against the rearmost portion where it is colored black.
jagosaurus
01-25-2011 12:41 PM
