REAR SPEAKER RATTLE SOLVED - easy DIY
As I had my car apart this WE I decided to look into this problem more closely for the poor sufferers of this problem . Happy to say that I am pretty sure this fix will solve it for everyone . I would rank it as 3-4/10 on the difficulty scale if you have never removed any panel. If you have then it is a 1/10 so super easy so the hardest part is just removing the panels.
Here are the photos identifying all the hard contact points that can rattle together and the solution for each point that I came up with. There probably is only one specific trouble spot but I wasn’t going to disassemble and reassemble each time after treating one area just to find this out. It just means you have to treat every single possible failure point like I did which is probably better in the long run anyways.
You will need to remove both the speaker baffle and the speakers and brace from the car
One lower arm of speaker brace could vibrate here so needs treatment
Remove raised ring from back of speaker baffle for tweeter
Remove small partial raised ring from around the tweeter case
Extra felt pad attached here
Extra foam strips here
Locating pins on cubby flap are felt wrapped
Wrap both holes at the base of the cubby flap. Bottom photo shows only half done so far on left hole
