Rear speakers
I know this has been done to death but
I am just about to fit some hertz legend mids and tweeters and a 8 inch ap8 in the doors
the rears are listed as sub's and mids
Well they seem frankly Dire and my question is do they only rcve a small amount of power from the amp as they just perform awfully and nowhere even remotely close to a sub or a woofer
I it the speakers or are only meant to be background sound
I have the meridian surround system
tks
tks
tks
tks
Here is the thread that I (audio noob) found invaluable and explains the in and outs of rear subwoofer dilemma
https://www.jaguarforums.com/forum/f...osures-244308/
Fantastic group of Members Jagbass,TH3FRB and Robrt8 all super knowledgeable and shows the discovery of this problem.
Do disconnect the OEM subs once you have installed your own . I ran with both but ended up removing them completely because of bass rattle/vibration and much better for it. The OEM sub can be disconnected by removing pin from the connector rather than cutting wires or desoldering so is entirely reversible.
I have photos of how to do this for you if you need .
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/90a0f607_2b95_4b65_b12e_3eb7a82c58e1_682b664a41402257afa620fb58e0a64aa06f0179.jpeg)
The white plastic inser needs to be removed first. Don’t forget to put it back in later
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/8ca4c254_d6e4_4b25_959f_02b1e258a16e_16cab2e80255c07cd91dc4445f349d056dbc2865.jpeg)
Easily done by releasing and pushing forward on the side tabs that hold it in place
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1680x2000/6e8cb916_bc9e_4b4b_9ecb_2d92673f0c1d_f6988bcfaa703bcbda0a89d916d7e7a8b3ed62b6.jpeg)
Release the pins by gently without breaking levering the grey locking tab downwards and wiggle pin out backwards
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/653e164f_dfc9_4524_b77e_cc652f88ce55_50572c714d726509ac021d2de847fd3f6c80a227.jpeg)
Need to remove blue and red wire. One for each coil of DVC subwoofer
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/064b3492_c02c_4697_8225_c3d12b085851_ebfff4b450e7dd32ab2d6c2538b45d673fd7f8b9.jpeg)
Isolate and zip tie the loose pins down
White and red are positive and neg for one of the voice coils. The other voice coil is green and blue. The subwoofer is a dual voice coil design so both voice coils need to be deactivated. Obviously you cold choose the other (green + white ) to remove or all 4 if you really wanted to but red and blue was at the top and the easier to remove. Like any circuit you only have to detach on e lead to break the circuit to make it inoperative. Orange and black is for the midrange back fill speaker so you do not want to touch those ones
you should also read
F-Type Stereo System Upgrade Planning Thread. Post 324 has a picture of the wiring colours and the correct ones to tap. You need to tap into the wiring harness so you can access the bass signal from the door woofers and not the wires from the subwoofer speakers which has bugger all signal as has already been mentioned before
Spikepaga
08-07-2023 06:23 PM
