Rear Spring Isolators Sleeves?
Hi guys,
My dealer has called and advised they've tracked down the slight rear clunking sound. Apparently it needs 2x "Spring Isolator Sleeves" fitted. Not sure if they're just missing or perished... Car is one of the first 2013 V6S.
Did this fix your issue? (assuming you've experienced it)
Does anyone have the part number for these? Is it T2R15835 ?
I'm considering fitting lowering springs in the near future, so seems little point in going ahead with this repair and removing the springs twice... Also I assume they'll be required with Eibachs or the likes? Or are the coils a different thickness?
