The storage compartment on the rear bulkhead of my car just won't seem to open no matter what I do. The button pushes in plenty but nothing wants to move. I've seen some mentions of latch adjustments etc but nothing that would explain what I should be doing next to try and get this open. Any ideas?
The 'rear stowage box' also locks, so I expect the lock mechanism has failed somehow. Some early cars were messed up (including mine), so that when you locked the car, the door would fall open rather than locking, so there was a TSB for that.
That does sound like a locking issue as you say. Does anyone have a diagram of this stowage box? My docs seem to cover the glove box and cubby but I can't find anything on the rear storage compartment.
It might be helpful if someone with that compartment could post a close-up pic of the latch. I believe that only the verts have that compartment. My coupe just has a pocket there.
With a pic, you might be able to use a credit card or other tool to open it.
Yes that would be great. I've tried wiggling some trim removal tools in there already but don't want to force anything until I'm sure of what I'm prying on.
[QUOTE=Unhingd;2113968]It might be helpful if someone with that compartment could post a close-up pic of the latch. I believe that only the verts have that compartment. My coupe just has a pocket there.
QUOTE]
This is correct:. The coupe does not have this compartment, and the owner's manual does not make this clear.
Thanks DJS. I can see the latch mechanism available as a part but the part photos aren't making it obvious to me how it all goes together. Could I ask yourself or any other obliging 'vert owners if:
- Do you get a click or some other feedback if you put your hand on the compartment door while you lock / unlock?
- Could I get a photo of the door while it's open, to give me a chance of levering things in the right place as I'm flying blind ATM
Take a flyer trying this:
1) disconnect battery for 15 seconds.
2) Put car in valet mode and then take it out of valet mode.
3) try opening the compartment.
Thanks so much DJS for taking those pictures. I shall noodle on what to do next. I couldn't feel any motion on the box when locking or unlocking the car which seemed strange to me initially but now I see how the rotating lock works probably doesn't mean anything.
I have a spare cubby box if you need parts. There is no electrical connection on the latch.
Thinking about it how much would you like for your spare box, noting that I'm based in the UK? If I had spares I might be more inclined to use extreme prejudice when trying to open the existing one....
I’ve seen your post from some time ago. Did you manage to get it open or work out the cause? I’m pretty sure it’s not connected to the electrics and is just a manual button to open - but maybe I’m wrong. Would appreciate know how you opened it and if you needed to replace the catch afterwards or if it just needed some lubricant. Cheers Arron
