Rear SVR diffuser/valance install on R?
DC
Mbourne (02-06-2021)
Thanks...I just ordered the lower piece as well...Not sure how long it will take to get here, and still working with a drivetrain issue/non-driving car right now...but will put it on (or try) when it gets here and I have my car back...
I figure worst case, I will have to order the other piece (and be patient) if it does not fit!
Good luck with yours...be sure to post some pics and info if/when you get it done.
DC
DC
DC
DC
IMO it has to fit without buying top part, but at Jag nobody was able to confirm this.
#28
This is the list of necessary parts I compiled right down to washers
Description Part No. Qty
Valance Panel T2R20049 1
Screw M5 x 12mm C2P22653 2
Valance Panel (Diffuser) T2R20874 1
Nut and Washer XR854810 7
Clip T2R16422 2
Bolt T2R19184 1
Shield T2R23157 1 Optional
Bracket T2R23823 1
Screw C2P23640 1
Clip T2R16422 2
Bolt T2R19184 1
Bracket T2R23823 1
Screw C2P23640 1
#30
I guess I will see when it comes in. The first place cancelled my order and gave me no reason...maybe they do treat these like Project 7 grilles? Not sure why...
DC
#31
#32
#33
apr1962 - I appreciate the info, and certainly not arguing, so thanks for posting(you may be 100% correct). My approach is simply, since we cannot verify for certain... I did not want to double the cost if not needed. After I get the lower valence, and test it, if it appears it won't fit...then we will know for certain and I will just have to order the other part(s) at that time...no biggie. But if I ordered them both, and found I only needed 1 of them...I would have a $600 paperweight left over
Will keep you all posted, if/when my part gets here.
DC
#34
#35
DC
#37
Well....This finally showed up today! It "appears" it may work with existing parts, but hard to tell. The installation in the workshop manual CLEARLY states to NOT Attempt install if it is cold...We are at 12 degrees windchill...so I think that qualifies and will have to wait. I am not sure if I want it white, or black? It has a pretty black shiny finish on it, so I may try it as is, and then paint white if I change my mind??
I have also included relevant portions of the manual for any others looking to install one. If/when it warms up, I will test out my new lift again...and see if I can rip the old one off and install?
If any others have now done this, please report your experience.
Take care,
DC
I put the procedure to R and R the SVR Diffuser on my drive HERE
Here s what the Lower Panel looks like:
Take care,
DC
#38
Take care,
DC
Take care,
DC
#39
Received 3,209 Likes
#40
Thanks,
DC
