Rear SVR diffuser/valance install on R?
#81
Wasn’t sure if this set up was an oem project 7 diffuser or some other option out there was hoping it was a cheaper solution lol but the info above answered everything else. thank you again for pointing me here
Therock88 (03-09-2021)
#83
#84
All info and part numbers are in the post and my DIY.
DC
#85
Well...This post was started last year, and prices change regularly, as well as everything seems to have increased since COVID. Just looked up the part at a Jag Dealer online and appears to be ~ $947...So about a 30-40% increase in price.
DC
DC
#86
#89
I just got done doing this install. Part was only available through Harper Jaguar and the most reasonable on shipping cost via freight in the US. Several other dealers either had a ridiculous price, ridiculous shipping cost or straight up told me it was not available. I paid $947 through Harper and they turned it around in less than a week including transit time. The install was super simple as already mentioned in this thread. Only additional thing I did was added a strip of 3M molding tape in the corner section of the different where it meets up with the upper black valance to give it a little extra support. Not required, but gave me some piece of mind. I did the install with the car on the ground, so you don't "need" to even jack it up, but it would be a lot easier if jack up or on a lift. Otherwise 6 torx as previously mentioned, unclip, reclip, screws back in and some tape. I only have one crappy picture because it is raining outside at the moment, but I will get it posted if interested eventually, but looks just like the others who have done this.
mrjohnt (09-09-2021)
#91
#93
This was amazing! Thank you for posting this!
My Pleasure...and thanks. It would be very easy to do without a lift. All you need to do is left the rear up enough to slide under to reach the bolts and push out the tabs. Really do not need it very high at all. Jacks/stands would work fine. I have a few pictures labeled, and will try to do a quick DIY and put it on here.
DC
EDIT: Here is a link to a DIY on my drive I put together with some additional pics that may help. Will also place on my DIY thread.
TheRock88 R to SVR Rear Diffuser DIY
DC
Thank you for posting this mod. Do you think that this would work on 2023 F-type P450? If so, what part number would I need? I tried to find under cover for newer F-type R models but they look quite bit different than SVR ones.
