Rear toe link
Replace the whole thing will always be the easiest but also the costliest, I will be doing lowering spring and rotors alone with it so trying to save a few bucks if these boots can be replaced individually.
Haven't inspected closely but the joint itself should be good, only occasional thump noise driving over bumps, 2 horizontal slits on the boot.
Not sure if i will find a solution, quick search online yielded some results from xk and xj community, lengthy read and may or may not apply to the f type.
fcpeuro also returned some result for Jaguar ball joint but none was for the f type and nothing looked remotely close. Some of them are from the same manufacture as the toe link i found on advanced auto part though, lemforder.
https://www.fcpeuro.com/Jaguar-parts...20ball%20joint
Attached is the part I’m referring to, pic was found online as i didn’t take pic of mine.
Most likely i will buy the whole unit and call it a day, it’s not horribly expensive, but if any one has experience to share that’d definitely be nice! I don’t think we are the only ones with this issue.
https://shop.advanceautoparts.com/p/lemfoerder-toe-adjustment-link-l2066945362lem/11816129-p?c3ch=PLA&c3nid=11816129-P&adtype=pla&product_channel=online&store_code=&&& &&gbraid=0AAAAAD05GhVxlmnA3EeQyiU6a0B8w1GHu&gclid= CjwKCAjwvJyjBhApEiwAWz2nLcxozU21gMHo4hfRhQkvpCT51w RH_Td8YlPSfvuvE6PuyRCyxT-J6BoCl0YQAvD_BwE&gclsrc=aw.ds
JgaXkr (05-20-2023)
Emailed zf North America service (lemfoerder), they directed me to fcpeuro, emailed them, nope, they don’t carry the part and can’t source the joint separately.
Looks like i will replace the whole thing, unless i really want the ~$200 saving😂
also found that the oe replacement part number c2d51044 fits quite a few more models like xf, s type, xkr, xk and xj of certain years.
Edit: scrape that, search is over
howdoyousayjaguar (12-22-2023)
