Is this the rear tow hook?
Old 10-30-2014, 08:23 PM
shift's Avatar
Default Is this the rear tow hook?
The rear bumper, take off the black cap, reveals this screw. Is this for the rear tow hook? The included tow hook fits the front location and is documented in the manual. But the manual doesn't mention the rear location and the included tow hook does not fit this. Is it something else? Or if it is the rear tow hook, anybody know the specs to order an aftermarket one?
Old 10-30-2014, 08:42 PM
WaltB's Avatar
At the very top of your picture you can see the bottom half of a hole. The tow hook should screw into that hole. Are you saying it does not?
Walt
Old 10-30-2014, 08:47 PM
shift's Avatar
The included tow hook does not fit, too big. Fits in the front though. Also kind of odd that the hole is angled. Think it wouldn't be good to be angled but maybe not.
Old 10-31-2014, 08:13 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
My car was delivered with a 2nd hook loose in the trunk, which I took out. Never checked to see if it would fit the rear, but that's my guess. Perhaps they used it as a tie-down on the ship?
Old 10-31-2014, 08:16 AM
shift's Avatar
Interesting, let me check again to see if there's a 2nd tow hook somewhere. Any chance u got it a pic? It's not the super big/long one that's next to the small battery, right?
Old 10-31-2014, 08:23 AM
DJS's Avatar
DJS
DJS is offline
Different setup in the vert, I think. The main hook is under a hatch on the left side of the trunk. I couldn't see anywhere to put the 2nd hook, and the manual doesn't mention it. I'll see if I can find it and post a picture.
shift (10-31-2014)
Old 10-31-2014, 08:59 AM
abedh's Avatar
There is a second hook and yes that is where it goes. I tried them out a while back. My rear hook came in the trunk loose as another poster has stated. It is much shorter than the front tow hook.
shift (10-31-2014)
Old 10-31-2014, 09:08 AM
shift's Avatar
Thanks. Checked the trunk, no loose tow hook. Guess the dealer removed it.
Old 11-03-2014, 12:02 PM
shift's Avatar
some closure...went to the dealer, checked another car, no rear tow hook. Guy said he's never seen one. So maybe some dealers toss them, others keep them. Who knows. But I did have the parts lady look it up and indeed there is a rear tow eye. So ended up ordering one.
Old 10-28-2016, 08:31 AM
Awd's Avatar
Awd
Awd is offline
An old thread....thought there was a more recent one but this came up on the search.
Asked my sales guy and the parts dept have come up with part one can order for a startling $53.99 (Can)
Apparently not something included other than special order.
So, as you slide off the road/track always rotate the car so the tow guy can use the front hook....or invest the $$
Old 10-28-2016, 08:54 AM
DJS's Avatar
DJS
DJS is offline
It was mentioned recently in another thread that Jaguar says the rear hook is NOT to be used for vehicle recovery or towing. Some of us didn't receive one; I did, but I don't keep it in the car.
Old 10-28-2016, 09:04 AM
Greggbhill's Avatar
As DJS mentioned, the other thread has a post with a service message...
https://www.jaguarforums.com/forum/f...type-r-169319/
Originally Posted by xdave
SSM70338 (A Jaguar Special Service Message) confirmes what we thought about the rear tow eye - it should have been removed from the vehicle and discarded during the PDI checks.
It is for securing the vehicle during transport only, and should never be used to actually tow or move the vehicle as it can damage the chassis.
The same is true for the F-Type, X351 XJ, old XF and the last of the XKs.
Orthodixie (06-07-2017)
Old 10-28-2016, 02:49 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
I'll sell you mine for half that price. Used just once.
Frenchy's Avatar
I got 2 tow eyes with my 2016 coupe. One is 5.25 in (13.3 cm), the other is 8.75 in (22.2 cm).
So can anyone confirm that (a) the larger one is for the front, and (b) the smaller one is only used as a tie-down during transport and can be discarded?
Old 10-28-2016, 03:26 PM
Unhingd's Avatar
That is confirmed. The larger front hook is stored in a styrofoam holder next to the battery.
Old 10-28-2016, 03:34 PM
DJS's Avatar
DJS
DJS is offline
I have a front plate mount that goes in the front tow hook (which I only use for annual inspections.) Took me quite a while to figure out that the front tow hook is reverse threaded. Doh!
Old 12-27-2018, 09:44 PM
Jaggyx's Avatar
Anyone know how to remove the rear tow cover and if they are the same between both V6 and V8 diffusers?
I tried to reach my hand back there, but it seems quite stuck and not sure I want to break anything should I be pushing incorrectly.
Old 12-28-2018, 04:03 AM
Carlisle Owen's Avatar
My ‘17 was delivered with two loose in the trunk.
Old 12-28-2018, 04:27 AM
scm's Avatar
scm
scm is offline
Received 1,481 Likes on 1,121 Posts
My MY18 manual says "Only tow the vehicle in a forward direction with all four wheels on the ground. Towing in a reverse direction or with only two wheels on the ground will cause serious damage to the transmission."
Maybe this applies only to later AWD models?
Old 12-28-2018, 07:21 AM
Carbuff2's Avatar
Hmmm. Does anyone flat-tow their F behind a motor home??? That would certainly eliminate the issue of limited trunk (boot) space.
Quick Reply: Is this the rear tow hook?
