Rear wheel (?) rubbing when pulling away slowly
Hi folks!
A few times lately I've noticed a distinct rubbing sound+vibration from the left hand side rear wheel area. It happens when I drive slowly away from my garage into the street, on a shallow left turn arc (on a level road).
My V8S convertible is stock, no mods (yet). Right hand drive of course.
Before I get into proper investigation (to gather evidence for the dealer), has anyone else experienced such a thing?
Can't find anything in the forum...
Thanks in anticipation!
Blkv8s (04-05-2016)
SinF (04-05-2016)
If it was tire rubbing, you'd see some scuffing on it. In that case, it would be caused by worn/out of alignment suspension component. Unlikely on a car of this age unless you put some serious miles over bad roads.
I think the most likely reason is brakes. It could be caliper starting to stick. It could be parking brake sticking. As someone suggested - do hard braking followed by coasting couple times, see if it resolve the issue. Also engage parking brake while very very slowly rolling (sub 1mph) to do the same for it.
Also, when was the last time you serviced your brakes? If everything original, it is not inconceivable to have early onset of sticking calipers.
I would be inclined to jack the rear of the car and just check wheel baring play on the lh side (grab the sides if the tire top and bottom-you shouldn't feel any movement) and also spin the wheel by hand and it will be obvious if the brake is binding.
Failing that, get the dealer to check the diff.
FS[Western US]: 20" Stock Nevis Rear Wheel
2010 Kyanite XFR
05-14-2016 01:02 AM
roberthornsey
03-11-2016 08:38 AM
