Recommend NJ shop to install crank pulley?
Hi everyone,
Can anyone recommend a good shop in NJ/NYC you've used for your F Type, preferably that has done the crank pulley swap?
I'm in Northern NJ but fine to travel. Purchased it this summer and looking to have it finally put in the R! Thanks in advance.
The following 2 users liked this post by Bierry:
Supersprint Sport Exhausts (09-19-2022),
Turko (09-19-2022)
I'm installing another SET in a F-type R this one i did in a XF Same procedure
https://www.youtube.com/watch?v=MWsi3cZ9oLM
On your XF you had enough room after fan removal to do the swap from topside. Do you know if the Ftype R has enough room to do the same? After removing the belly panels a few days ago room was so tight going from underneath which gave me pause. And I have to change to the smooth idler too. Thanks.
Bill
Removing the fan and going in from the top is what the service manual shows too. Removing the hood needs a second person to assist right?
Bacardi 151
08-19-2011 04:49 PM
