Removal of Windshield Trim Near Wipers
I have an XKR, but judging from the picture, this should be the same process. You have to remove the wiper arms by popping out the center cap and remove the nut. You may have to wiggle them a little to free them. The cowl should then lift out away from the windshield. It has a rail on the back side that just presses into a slot (sorry no pics). Mine also had a black adhesive/sealer where it contacts the windshield. Be careful of the washer fluid line that connects on the back, and don't forget to reattach that thing when it goes back together. I don't believe that you have to disassemble any of the false firewall to access the strut support bolts, but I have had more than one beer since I had mine opened up.
David Meier (06-29-2022)
Did you reseal the cowl with more of that adhesive when you put it back on? Any idea what adhesive it is?
Received 3,228 Likes
I just went through this. It was a little bit of a nightmare but maybe, just maybe tightening the brace bolts eliminated the clunking I have been hearing when the chassis flexes.
One tip - clean off and smooth over any excess with a rag or fingertip dipped in turps before it starts to cure, you have around 10 minutes which should be plenty of time.
Edit - I have twice tried to remove a wiper arm on my F-Type but gave up both times, it simply would not budge no matter what I tried.
But you can get a special tool for this quite cheaply, see here for example: https://www.ebay.com/itm/26449099182...3ABFBMvJfAkNth
Yes I have found the wipers to be tight on all the Jaguars I have worked on. A bit of trivia on wipers too? At least on the S-Type the inside of wiper blade hub is smooth when new. You align the wiper arm and then bolt it down. This forces the smooth bore over the grooved wiper drive pins. This makes it a VERY tight fit since it's basically friction welded on the grooved stud!
Don't know if other Jaguars are made this way or not?
It was a strange incident too? It was raining very hard and the road was covered in water. Everyone moving slow until a jerk-off in a jacked up truck decided to plow thru it all at high speed. When he came around me I had a huge wave of water pour over the car completely burying the windshield and the car. The automatic wipers kicked into high gear but with all the excess water it took so much force the wiper blade could not push it all away and the center grooved stud stripped the inside of the wiper arm out!
Yes I sure looked retarded driving around with only drivers side wiper operating!
