Remove seat belts
Remove seat belts
Hi guys. I have an F Type, and I would like to get colored seat belts. Therefore, I need to know how to remove our seat belts. Is there a "how to" article on how to remove Jaguar F Type seat belts?
Of course, I would have the seat belts sewn and replaced by a certified seat belt specialist, who I have used in the past. Thanks!
Anyone unaware of the importance of disarming the SRS before working on the seat belts could give incorrect or even dangerous advice.
Hi Graham. I'm not sure why you would delete the same post on the General Tech section. There might be someone who knows the workings of Jaguar seat belts, but who doesn't have an F-type, or visit the F-type section. And vice versa. I feel this is not only an F type question, but also a General Tech question.
I would like to post it again in the General Tech section for the reasoning above. Please let me know if you have an objection to this. Thank you very much.
As a basic principle, we don't want duplicate postings across forums. In addition, in this instance I didn't consider it appropriate for General Tech Help as it's a model specific question.
The only common procedure with seat belt removal on current models is the safety precautions required to deactivate the SRS prior to removal of the belts or buckles.
The issue is then one of seat and trim removal to access the upper and lower securing bolts. Each model has its own peculiarities in this respect and those likely to have any knowledge of F-Type trim removal will be found in this forum.
caunyd (01-19-2016)
Schwabe, so the Jaguar mechanics did it? I was hoping that I could do it at home, because I would need to send the seat belts out and that would take at minimum 1 1/2 weeks back and forth. And I don't want to drive the car home from the dealership without seat belts, or leave it there.
If you did the removal, or know how the dealership mechanics did it, please let me know. Thanks a lot!
Sean W
12-21-2015 08:10 PM
