Why would you even think about replacing the calipers?
That would cost $thousands, or at least many $hundreds, when you can repaint them yourself for peanuts, less than $10, all you need is a single rattle can of caliper paint.
The "in between" solution, still costings $hundreds, is to remove your calipers and send them to a shop to be powder coated.
Yea I agree, you'd be better off removing them and having them painted by yourself, or at a paint shop. We've done that many times here in NZ for customers, same thing with the wheels. Cheaper to take the ones fitted off to get painted rather than buying the painted ones.
The only thing with the calipers if the retaining clip on the outside wont have the Jaguar script, were as the genuine ones do, but you could buy that part from dealer if you are particular.
No need to take the calipers off, just paint them in place, I've done it dozens of times with never a problem.
Clean the calipers first, I use el cheapo spray can degreaser first then turps on a soft rag.
Then mask off the rotors around each side of the caliper, no need to go overboard.
Then spray on two maybe three light coats of caliper paint, leaving at least 20 minutes and preferably an hour between coats. Keep each coat light, too heavy and the paint will run.
Then let dry for at least 24 hours before you apply decals/stickers and/or clear coat.
If you use clear coat it must be the exact same type of paint (and preferably the same brand) as the base/colour coat, otherwise you risk dissolving the base colour! I use Dupli Colour, never had a problem with it.
Once the paint is dry clean any overspray off the brake rotors with turps and a rag, no need to be too fussy as any small amounts left behind will be removed by the action of the brakes.
Here's a pic of the old XFR a few days after I painted the calipers and whacked "R" decals on:
And a pic of the F-Type after I whacked new "Jaguar" decals on:
How hard is it to remove the calipers yourself and paint them? I've done brake jobs on normal cars, is the f type similar? I don't wanna risk anything and at the same time I trust myself more than any place that paints calipers
There are also red or yellow caliper covers, logoed, that just clamp over existing calipers on EBay.
I track my car and that would make my brakes melt, even on daily use I would heavily recommend never putting anything like that over your calipers. extremely dangerous
On a lift, right? Would I be able to reach every area of the caliper evenly?
No need to do it on a lift, flat on the ground is perfectly OK.
You can still reach with a spray can every part of the caliper that can be seen with the wheels fitted.
Never seen them done in white, that would be novel, but I reckon yellow would be better, maybe even the golden yellow you see on some Porsches.
hmmmm I agree white is a little Jersey Guido but I thought it would look good with the interior...But yellow is def the front runner any more suggestions
