Replacing Fake front Vents for real ones
DC
They get plenty of fresh air. It is fed directly from the front Grill opening through two large tubes that attach to the side of the airbox. If you open up those fake grills, you will just get a lot of water and crud on some wiring, and the airbox itself....no benefit at all that I can see, unless you create ducts to cool the brakes perhaps??
The ducts were discontinued because they were designated for dry track use only on CCBs and people were using them on the street causing the issues Rock brought up plus scoring the rotors.
DC
DC
So I would leave them blocked
DC
This is from open front grills Was an annual cleaning process...
Had to build mesh grills to keep stuff out!
Something else I learned from big open front vents on the Porsches... When you open them up, all sorts of goodies end up wedged in there. I literally found a piece of a dried corn cob on my radiator of my 997 TT. Ended up building screens/mesh grills to block it....
DC
DC
DC
Good to know! I have had it off a few times and did not have any, so lucky so far. I will do the same annual cleaning process on this car as well to ensure no issues. Ended up having to replace one of the radiators on the 997 TT due to the junk, and pebbles etc., that bounced in there.
DC
DC
I'm not really seeing there will be less airflow in the heat exchangers after switching to the more open new grill and removing the blocking fabric around the center post. I will fabricate a streamlined thinner, less blocking, center post structure for my own for stability and tow hook.
Unhinged, forgive my lack of knowledge but would you elaborate on the horizontal heat exchangers and the front belly pan. I don't see anything obvious and don't want to go poking around without knowing what I am doing. Given the leaves here - especially those lousy locust trees whose little leaves get into everything - I am sure cleaning will be necessary.
The horizontal slot just behind my plate will collect massive amounts of leaves. There’s at least one horizontal radiator upon which those leaves will accumulate. You could try to dig them out with a clothes hanger, but is far less risky to just remove the front pan. Any vacuum cleaner nozzle slender enough to squeeze through the slot is probably too small to effectively suck up the leaves.
Received 3,259 Likes
When I removed the undertray and the black plastic "box" under that some 3.5 years ago (to replace my damaged splitter/diffuser) the build up of leaves and muck on the radiator(s) was very obvious and relatively easy to brush out.
I attached a PDF for the removal process - Stohlen did the best job I have seen to date of documenting the process in his Lower Pulley upgrade DIY Thread...So full credit to him...I just filtered out the Lower Tray info for you from his thread. I have done this process many times, and it is easy to do....just time consuming because of the numbers of screws! JLR must have found a sale at Home Depot on screws
DC
Therock88, thanks to you as well. Does look straightforward but as you say time consuming.
I don't think they needed a Home Depot sale, they are British after all. Overkill on the detail which we, of course, all love. A Porsche on the other hand would have about three screws total.
And very true on the Porsches! I have torn them apart for years. Not only is it 3 screws...they are unique, require a special tool, and if you turn them wrong they break, and cost $50 each
Good luck with it.
DC
