Replacing headlight bulbs/globes Query
When you talk about melting wiring harnesses and popping fuses, you may be talking about halogen bulbs. OEM halogen headlamp bulbs are around 50-55W. It's true higher wattage halogen bulbs produce more light, but as you suggest, the added accompanying heat can (and does) melt/damage wiring and switches that were only designed to handle lower wattage bulbs. (One way around this is to run a relay set-up, but that's another story).
When you say "8K," you're talking about a specified range of color for that bulb (light source), in this case, 8000K degrees Kelvin (K). The Kelvin scale is not based on the actual temperature at which a bulb filament (if a halogen bulb) or a discharge arc (if a xenon bulb) burns or the power it draws, i.e., wattage (W). Think of the Kelvin scale as a gradient of color hues rather than a unit of electrical power (wattage).
The following 2 users liked this post by Burt Gummer:
deltagroup (03-09-2017),
Misujerr (03-16-2017)
OEM Xenon lighting systems/bulbs I've seen (not those halogen bulbs touted to contain xenon gas) are pretty much standardized at 35W consumption.
Yes, I was after 8K colour but to allow for the drop in brightness, go higher in wattage, but apparently as you say 35W is the standard.
I just installed these with no issue. 5000k looks perfect.
HID-Warehouse HID Xenon Replacement Bulbs - D3S / D3R / D3C - 5000K Bright White (1 Pair) - 2 Year Warranty
The high-low beam is the same lamp (one bulb for both, at least on the 2016 US R model I have). An internal baffle is moved for the high-beam pattern. So, yes - mine work great for high/low. I really like the whiter lamps.
I think I had to use a 10mm socket to temporarily remove a terminal block on the passenger side to get that one installed.
Burt Gummer (03-24-2017)
i decided to try the philips ultinon 6000k again, bought a set from TRS
they arrived in different packaging from my first set, and they clipped in easily this time
the colour has a light blue tinge, it actually looks like the exact same colour as osram cbi in a d2s (ie: with mercury) - these mercury free d3s bulbs just lack colour at all kelvins. the led side light that illuminates with steering angle/indicators actually matches the colour output of the bulbs now
i'm driving around with my headlights on all the time, hoping they burn in and lose the blue tinge for more of a pure white - what i do like is the purple cut-off, and haven't really noticed any significant drop off in lumens compared to the cbi
David Meier (10-11-2019)
