Replacing Hood Bonnet vents
Interested in swapping these out for something a bit more interesting. I can see how the little tabs underneath hold the vent in, plus a pin and a larger tab. My question is what is going on with the upper part... no pins or tabs. How is the top end held in? there appears to be some sort of blackout material the covers the metal in the top part of the vent. See from underneath, there is the material in the 'oval'. This is a MY2017 Premium Coupe, supercharged 6.
They are a bit long and now I am reminded that I should cut the down. I do have the black Mina vents and if you are interested PM me and I will consider parting with them.
Below are some pictures of the original mesh vent. To remove, start at the pointy end and push in the tabs of the clips, one at a time. Each one should let the vent come out a little farther so they don't re-clip themselves as you work back. The hidden part has a locating pin in the center and two clips. The clips are not that big, and once all visible clips have been disengaged, these should pop loose without much force.
First, the whole vent, removed from car:
This is the back, hidden from view.
Received 3,226 Likes
I removed mine a few years ago (to Dremel out more of the middle for better air flow/cooling) and I pushed the clips in from the back/underneath with a screwdriver.
After looking at the vents and without any instructions I assumed this was the best/correct method as I thought attacking them from the top/front would risk scratching the paint.
With the first vent I discovered what George111 talks about - it popped off and slid down the hood/bonnet before I got to the last two clips but luckily it didn't scratch anything. So I was a little more careful with the second vent!
